Coilover Install (Tein Basic)
Originally Posted by bmsciontc
ok first off great write up. i only have one question. what do you do about the rear wheels, my friend lowered his car with tien coilovers also and he set it so low that the tires did not sit right...he ended up burning through his rear tires in an unatural amount of time. is there a fix for that or do you just need to get an enlighnment? thank you
Music City Scions
Originally Posted by DonNguyen
why'd you list a 24mm socket?
Originally Posted by saberz
Originally Posted by j3st3r
Originally Posted by daffy12
just bought these. should be coming in on friday...i guess ill be following this
I have one!! What wheels are on the blue tc? Love the write up though, I'm thinking about dropping my car some, but im not sure how it would look on stock wheels
Awesome write up!!
If this had been around when I changed my stock shocks and springs to TRD shocks and springs I could have saved a couple hundred dollars. It seems like the installation is pretty much the same and pretty straight forward going by your guide.
Excellent job!! Deserves to be in the tech section.
Music City Scions
Originally Posted by Domo
do you need a spring compressor for the rears if your getting Tein SSP Coils?
Will this diy work for installing ksport coilovers??
Music City Scions
oh nice..so I guess everything is just plug and play for the rears as well, hey if you dont mind me asking. Was the EDFC controller worth it? And the EDFC can be used on the rears as well?
Music City Scions
^^thanks, so let me get this straight, am i putting the anti-seize in the hole where the 22mm strut bolt goes into? Or do I place it on the coilover where the rings that control the height are? The reason im confused is because if its on the coils, then i could do this earlier..right?
You can also put it on the bolts . I put a bit on the coilover rings because it will prevent it from seizing/rusting, plus it will make it easier to adjust the height or lower it in the future.
