tC Tech and DIY Info for the Scion tC
Needle Color Change
Old 09-17-2005, 01:14 AM
mandos's Avatar
Default Needle Color Change
First off, sorry these pics are awful, no camera here, just phone.
Pop your needle off the instrument cluster like has been shown many times before.
On the back of the needle, you'll notice two small plastic bumps where the back piece is melted on.
You can kinda see them below the two vertical oranges lines there. Take a soldering iron and pull the plastic down to one side. Now just pull on the center pin to remove the back.
After you've got the back off, grab the base of the needle and pull up, it'll just slide up the two plastic pins holding it in. After you've got the needle out of the base, swab it with acetone to remove the color.
Now, put two pieces of electrical or other tape on either side of the needle to make painting easier.
I used an acrylic paint since it's what you can get in the craft section at Wal-Mart for 87 cents
That's what it looks like w/ tape on either side painted. I made mine white because I'll be doing white LED's attached for needles but they aren't cooperating right now, I think I bought ones that are too small for me to solder
Edit...PUTTING THEM BACK TOGETHER.
Slide the needle back onto the pins inside the housing.
Pop the backing back on, on the two smallest needles(temp and gas) there is no guide for which side covers the needle, but there is the metal counterweight. For the tach and the speedo, there'll be two prongs that go around the needle.
After you get it locked back in, just melt the plastic back over the spot you removed it from and it's resealed. YAY
mandos is offline
Old 12-13-2005, 06:22 AM
JSVH's Avatar
nice, thx
JSVH is offline
Old 12-13-2005, 06:24 AM
tcholic's Avatar
nice.......i might do this weekend...
tcholic is offline
Old 12-13-2005, 02:18 PM
ScionDad's Avatar
Nice - very nice.
Oh, 1 more very important comment
Please tell me you "found" the Cosmo magazine!
ScionDad is offline
Old 12-13-2005, 02:21 PM
Stu_Gotti's Avatar
Stu_Gotti is offline
Old 12-13-2005, 02:31 PM
Scionetics
MTcX's Avatar
I'm anxious to see what this looks like when its finished. if you can get an actual camera to see the true colors of whats going on
MTcX is offline
Old 12-13-2005, 03:27 PM
mandos's Avatar
ScionDad...it's the girl friends. Before she had a job that actually gave her hours, I just bought her Cosmo's to keep her happy.
MTcX: It is done ;)
Looks f'ing sexy IRL. The picture came out kinda wierd on the side gauges. They all look like the middle one does for real.
mandos is offline
Old 12-13-2005, 03:38 PM
Scionetics
MTcX's Avatar
that looks great. So what color did you paint the needles then, I'm colorblind so sorry for asking an obvious question. If you don't repaint them after removing the original paint will they be clear and you can leave them that way or do you really need to repaint them?
MTcX is offline
Old 12-13-2005, 03:46 PM
mandos's Avatar
I put them as white...to allow some distinction between the needles and the silver panel they're on. Otherwise it would have been a huge pain to see during the day. As it is it's still very easy to see out of the corner of my eye.
Plus, I have white needles on blue guages=sexy.
mandos is offline
Old 12-13-2005, 04:25 PM
ScionDad's Avatar
Sure wish I had done this when I did the LED changes. Sweet looking mod.
ScionDad is offline
Old 12-14-2005, 11:58 PM
Sam_J84's Avatar
white needles look tyte
Sam_J84 is offline
Old 01-23-2006, 03:24 AM
friday24864's Avatar
Just an extra tip: Use a neon red, green, or blue acrylic paint. I learned the hard way.
friday24864 is offline
Old 04-14-2006, 10:59 PM
DannyMiggz's Avatar
finally, putting "Cosmo" to good use, lol.
DannyMiggz is offline
Old 03-22-2011, 12:22 AM
jdm_evotc's Avatar
im liking those white needles has anyone done yellow
jdm_evotc is offline
Old 04-08-2011, 01:49 PM
psturm's Avatar
Looks good! I did mine blue a while ago and they still look great! good write up
psturm is offline
Old 12-02-2014, 05:59 AM
Miguel22's Avatar
Default Important question!!!
I recently did this to my scion tc and now im not sure i put the needles back in their proper place. How did you know where to place them???
Miguel22 is offline
Old 12-02-2014, 04:35 PM
electrongeek's Avatar
When I did my led gauge swap, I followed a tutorial I found on this site I believe and it described how to correctly reinstall the needles.
If I remember correctly, the proper way to do it is to place the needle back on the stem, but not all the way down, just snug enough to keep it in place for calibrating.
Once the needle is on you want to carefully move it back towards zero until you feel a little resistance and stop. It might take a few tries, but it's fairly easy.
It's been awhile since I did my gauges so my memory might be off. Run a search for that tutorial to be sure. I hope that helps.
electrongeek is offline
Old 12-03-2014, 03:56 PM
Basebllstar's Avatar
That. ^^
I marked where they sat on the gauge face before I removed em.
And you push em down until they're close, but not touching the gauge face.
Basebllstar is offline
MonsterunderBed0
02-17-2015 08:42 PM
mrsocks
01-20-2015 01:29 PM
DR_xB
07-20-2004 08:31 PM
DirtyThirty
14
01-16-2004 04:48 AM
wonderworm
11-08-2003 05:42 PM
Quick Reply: Needle Color Change
