tC Tech and DIY Info for the Scion tC
Tail Light Install
Old 05-12-2008, 02:09 AM
FLEA's Avatar
^Usually if that is the case then you might be pushing the right area but wrong part. Push down on the very end of the tab and then pull, it should disconnect. If that doesn't work trying pushing down, wiggling, and then pulling.
FLEA is offline
Old 06-13-2008, 01:23 AM
juanchoTC's Avatar
just what I was looking for....this weekend i'm changing my tails...thx.
juanchoTC is offline
Old 06-13-2008, 01:31 AM
FLEA's Avatar
Have fun...let me know how it goes!
FLEA is offline
Old 06-24-2008, 05:00 AM
Rogue_Dragon's Avatar
I just used this post to install some aftermarket LED tail's today. It worked out great. Thanks for taking the time to post this DIY. It really is appreciated. "2 thumbs up"
Rogue_Dragon is offline
Old 06-24-2008, 05:06 AM
Sciontistical_One's Avatar
VERY useful DIY... if it wasn't for his thread, I might have had a very difficult time installing these...
I took a shortcut though... I only removed the screws in the wheelwells and the top of the bumper... I just tilted the top of the bumper back far enough to work on the lights.
Made the process just a little quicker...
Sciontistical_One is offline
Old 06-26-2008, 03:24 AM
ScionJim23's Avatar
interesting shortcut? never thought of that. was it hard to bend back?
ScionJim23 is offline
Old 06-27-2008, 12:25 AM
No, not really hard, and you don't want to "bend" it, just tilt it back far enough to get the lights in and out. You still have to separate the bumper from the fenders, but since the top of the bumper slides into the bottom of the lights, it doesn't take much.
Old 09-14-2008, 09:29 AM
tClumpiaz's Avatar
Anyone know what the part number for the screw is on the rear bumper? It's one of the two screws you see when you first open the hatch. I need to order a replacement for that. Thanks for the help.
tClumpiaz is offline
Old 09-30-2008, 10:57 PM
BRadiculous's Avatar
this write up is perfect! i just used it and had absolutely no problems. just make sure that you arent an idiot like me and put the bulbs from your old tails in your new ones if they dont have them. hahaha
BRadiculous is offline
Old 10-03-2008, 04:57 AM
nrgwar's Avatar
great write up thx ;) I might install my smoked out tail lights this weekend now A++
nrgwar is offline
Old 12-24-2008, 02:13 AM
geo46_2's Avatar
this was very useful since i had to replace one of my tail lights , anyways the only problem i ran into was i had mudflaps the bottom screw clip was a little hard to remove but i finally got it out lol .
geo46_2 is offline
Old 01-11-2009, 08:40 PM
Fanatik's Avatar
I think it should be noted that those tails are a PITA to pull off. I had to pull both of them VERY hard to get them to pop off after everything had been removed. Some of you might have the same issue... so if they dont come right out, you gotta pull em HARD! I mean put some AZZ into it =D
Fanatik is offline
Old 02-23-2009, 11:11 PM
getaforknjob's Avatar
Excellent write up!
I followed it step by step and it was perfect!
getaforknjob is offline
Old 04-07-2009, 02:23 PM
jdscion06's Avatar
quick question - I have the mudflaps also and I am trying to install my TYCs today. Can someone explain to me where that clip under the wheel is located? I cant seem to find it - do I have to remove the mudflaps to see it?
Thanks in advance! Sorry if this is a very nooB question.
jdscion06 is offline
Old 04-07-2009, 02:43 PM
jdscion06's Avatar
nm I got it. Thanks
Old 04-18-2009, 06:26 AM
tCtCtC's Avatar
i wanna make this note...
if you have a rear lip, you WILL need to unscrew the sides, or else itll hold on to the lining.
tCtCtC is offline
Old 04-18-2009, 06:40 AM
FLEA's Avatar
^True, but if you try to remove the bumper with the lip attached....that's just stupid. Pure common sense to remove the lip first.
OEM GFX lip doesn't need to be removed.
FLEA is offline
Old 05-18-2009, 08:05 AM
FLEA's Avatar
Hope this DIY helps.
I am done with these forums.
Any questions, email me at kennon7mills@gmail.com
Later!
FLEA is offline
Old 08-07-2009, 04:46 AM
FLEA's Avatar
Updated first page, later!
FLEA is offline
Old 08-07-2009, 04:58 AM
Murphys_Law's Avatar
updated by removing it?
Murphys_Law is offline
Quick Reply: Tail Light Install
