xA Tech and DIY Info for the Scion xA
Ground Wire Kit Install (Homemade)
Old 01-21-2005, 01:35 AM
  #41
tbone587's Avatar
crap, why does the thing in tutorial show u need 10 ring terminals? Should we only need 8?
tbone587 is offline
Old 01-21-2005, 01:45 AM
  #42
jct
jct's Avatar
its for extra if you mess up
jct is offline
Old 01-21-2005, 02:28 AM
  #43
tbone587's Avatar
crap, too late now, I already ordered 10. what size shrink wrap do I need for 4 gauge wire? My dad sells shrink wrap, so I just need to get him to bring the right size home. For 8 foot of 4 gauge wire and 10 ring terminals it cost me like $22 total. How do I go about crimping the terminals on the wire? are the terminals bendable enough to do with standard pliers?
tbone587 is offline
Old 01-21-2005, 03:03 AM
  #44
jct
jct's Avatar
you need a crimping tool or as timinaz said
Originally Posted by timinaz
Another tip is to use a hammer to crimp the wire and the lugs.
jct is offline
Old 01-22-2005, 05:44 AM
  #45
jct
jct's Avatar
i installed it in 41 minutes due to that it was freakin cold out and i used real 8 gauge wire and not the flexable speaker wire kind of hard to manipulate the wire into the direction i need but i got it on there
i froze my hands that i could feel the bolts and nuts when i was putting it back together now that was the hard part lol
jct is offline
Old 01-25-2005, 02:12 AM
  #46
tbone587's Avatar
My wire and connectors came in the mail today. Here is a picture of my ground kit I made.
tbone587 is offline
Old 01-25-2005, 06:35 AM
  #47
mikochu's Avatar
Looks good, tbone! I hope you measured the wires in your engine bay!
mikochu is offline
Old 01-25-2005, 10:29 AM
  #48
hotbox05's Avatar
that looks to be an expensive wire kit. i wanna go with a regular 18.00 ebay kit soon
hotbox05 is offline
Old 01-25-2005, 12:00 PM
  #49
DeepSouth Scions
Ashe_WCM's Avatar
Dont you mean the $38.00 ebay kit?
Almost every single one I've seen charges around $20 for shipping, I like the one that says "M.S.R.P. $199.99"
Cheaper to make your own.
Ashe_WCM is offline
Old 01-25-2005, 03:20 PM
  #50
tbone587's Avatar
Lol I made it myself with wire i bought online for 20 bucks total... I didnt measure anything I just followed the tutorial.. Wow Im about to go check it out and now im a little scared..
tbone587 is offline
Old 01-25-2005, 06:06 PM
  #51
tbone587's Avatar
When I was "crimping" the connections last night with a hamer, there was 1 connector that wasnt really on good, but I figured it should be ok. I go to power on my car and the rpms seemed like they were higher than before (probably my imagination), but It seemed like it accelerated faster as well (probably my imagination). Anyhow, I just wanted to open up the hood one last time to make sure everything is secure. I wiggled all the connectors, and they all felt solid as a rock, except the one.. So I give it a slight pool and the wire pulled right out lol. So I gotta go run to a local audio shop and pick up some more connectors cause i dont have anymore. Since the bad connection is on wire a, it basically defeats the whole purpose lol
tbone587 is offline
Old 01-25-2005, 06:31 PM
  #52
OhioScions
xbox83's Avatar
quick question....why did you choose those grounding points....are those the same that sun, apex'i, and other companies use for our cars or did you choose those at random (which i don't think you did...you seem like a smart guy). just curious why you chose those points...like if there was a significant reason and what not.
-X
xbox83 is offline
Old 01-25-2005, 06:36 PM
  #53
mikochu's Avatar
-X
Sun, Apex'i, and other JDM companies don't have exact ground points for our cars. I just used the logic of grounding the engine and body. You could ground your alternator and transmission (auto?), but that's up to you. I just did the simple body>battery>engine>engine>body. *shrug*
mikochu is offline
Old 01-25-2005, 06:41 PM
  #54
OhioScions
xbox83's Avatar
no i have a 5 speed so that wouldn't really matter...i understand your logic casue its one huge pathway for everything to ground to. helps voltage everywhere under your car find the quickest point to ground itself....i was just curious excellent DIY i'm very impressed by everyting you've done thus far...was thinking of doing a few and posting it up on here but you know i didn't want to take all of your glory
-X
xbox83 is offline
Old 01-25-2005, 07:02 PM
  #55
kkawana's Avatar
im just hopin the ring connectors i bought will work.. only got 1 pr of 8gauge connectors cuz thats all the store had when i bought the wire.. went to lowes, home depot, schucks... they seem to jump from 12-10gauge to 4gauge..then 0gauge...never found 8gauge..so bought a pack of 12-10 gauge.... hope they work
kkawana is offline
Old 01-25-2005, 08:12 PM
  #56
tbone587's Avatar
ok guys, I have it all done now, I bought a new connector for theone I messed up, and put it back in and dang.. Before I did the ground kit my engine would fluxate at the 2 mark and above. Now it doesnt even budge from the 1 mark.. I dont understand how it works, but it does. It definately accelerates faster, its not my imagination. When I press the gas down its much smoother now. I also tested the static shock I used to get when I wore this fleece shirt I had. Now no shocks when getting out of the car Nice tutorial guys. If you want to get the same 4awg wire and connectors as me, go to knukonceptz.com. The total "kit" should be about 20 bucks.
tbone587 is offline
Old 01-26-2005, 02:42 AM
  #57
jct
jct's Avatar
i froze my hands that i couldn't feel the bolts and nuts when i was putting it back together now that was the hard part lol
jct is offline
Old 01-27-2005, 04:29 AM
  #58
Xbilly's Avatar
I made mine without ring connectors because I am cheap. I used Left over amp wiring cuz im cheap I'm going to try to put it in tommorrow, Im only using this temporarily though... I'll post results if this is effective
I cant seem to figure out how to inlude pics so if yer interested pm[/img]
Xbilly is offline
Old 01-27-2005, 04:31 AM
  #59
Xbilly's Avatar
BTW its one continuous wire 7' long no breake
Xbilly is offline
Old 01-27-2005, 10:49 AM
  #60
hotbox05's Avatar
ebay 19.00 kit here i come. well .01 and 18.99 shipping , lol
hotbox05 is offline
Quick Reply: Ground Wire Kit Install (Homemade)
