Gauge Lighting: Changing color
#81
The Gauge cluster in the xB uses PLCC2 sized LEDs. If you want to change out the LEDs behind the Clock, they are 1206 sized.
You can get the PLCC2 LEDs from Oznium (http://www.oznium.com/plcc-2).
As for the 1206 LEDs, you can get them from most any electronic parts supplier I personally use http://mouser.com.
Just make sure that the LEDs have a mcd of at least 100 (brightness).
#88
Re: Odometer Miles
Originally Posted by martin_barrera
A and B miles...What does this mean?
eg: looking at your odometer, press the little stick that pokes out of the cluster beside/below it (depending on which vehicle you're driving). You'll see the odo change between Odometer, Trip A, and Trip B.
The trip A and B Odometers can be reset to 0, where the straight Odometer cannot.
Hope that helps!
#91
Re: !!!
I modified my gauge but it seems that I put the hands' back incorrectly. I mean....I filled up my tank and it shows up as 3/4 full. Any one have the same problem? How do I fix it???
http://www.forcespeed.com/XBInstall/XBInstall.htm
#93
i was able to do it for the xA. it's a little bit different but pretty much same concept. basically keep removing the top layers which are very easy to take off. the rpm and fuel needle i just put it on Empty and 0. the mph needle was a bit tricky. my last resort which worked, drive without the speed needle for like a block, park it, place the needle onto 0 and it should work. if not, then turn off your car after placing the needle and turn it back on. here are some pics:
#99
