2011-____ [ANT20]
O.G. Black Mamba Thread...Back At It Again!
Old Jul 31, 2011 | 04:33 AM
  #61
Backinblacktc2's Avatar
So I had a busy day today. I installed a TWM SHORT SHIFTER,MUD FLAPS, and DESCENDANT DECALS ............7/30/11
TWM PERFORMANCE SHORT SHIFTER:
The shifter took me about 2 hours to install the directions are on point even for someone like me with no formal mechanical experience. I enjoyed every moment of the install and now my car shifts flawlessly and quickly. The short shifter is tight and not sloppy like the stock shifter and shifts with little effort. Added a couple install pics below.
Install pics:
please excuse the mess!!
2 hours later and im done!!!!!
OEM MUD FLAPS
Install is simple for the rear 2 flaps you need to drill 2 holes on each side 4 holes total Just look for the pre dimpled indentations on the inner fender. the reason why i got them is because my car seems to love to pick up rock and fling them everywhere like right into my paint lmao problem solved and they look great because my car is black so they blend right in.
FRONT:
REAR:
DESCENDANT DECALS:
The camera does not pick it up but all decals are [MIRROR CHROME]
Front Window:
REAR WINDOW:
Drivers Door:
Passengers Door:
DESCENDANDT CAI (Got the idea from WELLSLEY)
Old Jul 31, 2011 | 04:50 AM
  #62
Scion202's Avatar
lucky you....i've been moving into into a new house all day and will be for the next couple so no time for new stuff
Old Jul 31, 2011 | 06:25 AM
  #63
goose_119's Avatar
i want your hood
Old Jul 31, 2011 | 08:17 AM
  #64
KidJustin's Avatar
DaYUUM/Scion Evolution
went a little too crazy with the descendant decals....but hey its interesting
where did u get them all? custom made?
Old Jul 31, 2011 | 12:44 PM
  #65
MightyP's Avatar
Looking good!
Old Jul 31, 2011 | 02:25 PM
  #66
jtk2's Avatar
cars coming along nicely! the decal on the front windshield looks extra sexy!
Old Jul 31, 2011 | 04:15 PM
  #67
@ Scion 202 great now i will have a chance to catch up lol!
Originally Posted by goose_119
i want your hood
@ goose_119 its sick in person bro it really changes the whole look of the car now is someone would come out with a body kit or lip kit than id be happy!!!
@kj world-racing sent me the logo thru my e-mail and had my Sticker Guy cut them custom made. Yea i did go crazy with the decals i did it for a reason they look great in person.
Originally Posted by MightyP
Looking good!
@MightyP Thanks bro!
@jtk2 Yea its my favorite one!
Old Jul 31, 2011 | 04:47 PM
  #68
MightyP's Avatar
Who'd you contact at World Racing to get the sticker stuff? And what format did they send it in? I'd like to do their logo in red.
Thanks
Old Jul 31, 2011 | 05:28 PM
  #69
Thanks
Cousin ROB,(Rob Cardona) The file was sent as an ai . but I used Adobe Illustrator to convert it into a JPG i than downloaded it onto a usb stick and took it to my sticker guy.
Old Jul 31, 2011 | 05:37 PM
  #70
MightyP's Avatar
^ Thanks, I'll hit up Rob.
Old Jul 31, 2011 | 07:14 PM
  #71
KidJustin's Avatar
Originally Posted by Backinblacktc2
Cousin ROB,(Rob Cardona) The file was sent as an eps. but I used Adobe Illustrator to convert it into a JPG i than downloaded it onto a usb stick and took it to my sticker guy.
Kareem sent it to me in a .ai format...but i still have to get it measured right and sent to my sticker guy
i also trying to think of how to stick it on the first tube instead of the second
...the second has more room...but if i change it to short then the lose the sticker....
there isnt much room up top because of the MAF sensor
Old Jul 31, 2011 | 08:41 PM
  #72
xtC2's Avatar
Does the TWM short shifter change the actual height of the shifter?
Old Jul 31, 2011 | 11:38 PM
  #73
No not at all but does reduce the throw by 30%
check out this video and in my opinion it is worth it 100% the gates for the gears are defined and tight, it shifts so smooth and quick its a must have for a STANDARD i love it!
Old Aug 1, 2011 | 12:42 AM
  #74
Thumbs up
Today I insulated the AC line got the idea from SCION202 but i took it a step further and added Heatshield CFT Cool Foil Tape. The results are amazing as he stated you only have to turn the AC on 2 and be totaly cool insted of on 3 or 4 and just be ok . Great job for the DIY SCION202 it works.
FRONT
SIDE
BEHIND THE ENGINE
Old Aug 2, 2011 | 01:22 AM
  #75
Druidiron's Avatar
Probably a dumb question, but is this going to make the line so cold that it could freeze up the condensor and or compressor? I think its a great idea, I just wonder if there is any negitive long term effects.... Thanks!
Old Aug 2, 2011 | 02:21 AM
  #76
Scion202's Avatar
well the main purpose is to keep the heat out and NOT to keep the cold in.
the cold will be as cold as it was initially designed to be. just without the drawback of having a ~300 degree heater next to it
Old Aug 2, 2011 | 05:09 AM
  #77
SoulShinobi's Avatar
The system is designed to reach roughly 40 degrees F, with the insulation it will do so quicker, which will result in the compressor working less (either by cycling off more often, or reducing its flow if it's a variable displacement type) which will result in less HP loss and better fuel economy. We're simply allowing the system to work more efficiently, it's designed to maintain the ideal operating temperature regardless of circumstances. In high heat it might not be able to reach that 40 degrees, but with the insulation it may.
Old Aug 2, 2011 | 01:54 PM
  #78
ROCKLANDTOYOTA's Avatar
COOL FOIL TAPE doesn't look as good as the black insulation but still does the job.....
Old Aug 6, 2011 | 10:13 PM
  #79
8/6/11...TINTED TAIL LIGHTS
Let me start off by thanking Superpickel for explaining step by step how to tine my tail lights.
So i used VHT Nite Shades and DUPLICOLOR clear coat and a whole host of other products(check the pics) it came out great its not as dark as it looks. THIS IS NOT A D.I.Y. IF YOU ATTEMPT SO IT IS AT YOUR OWN RISK AND IM NOT RESPONSIBLE!
BEFORE:
PRODUCTS I USED:
Sanding my lights:
Second coat of VHT Nite Shades:
Third and final coat of VHT Nite Shades!
Clear coat after 4 coats:
DONE!!! just in time for a car wash!!!!
Old Aug 7, 2011 | 01:16 AM
  #80
Scion202's Avatar
Night shots!
