Scion FR-S Forum - The Scion sport coupe
tC -> FR-S.....and I am back!
Old Feb 15, 2012 | 10:41 PM
  #1161
1293RS7's Avatar
Originally Posted by Scion202
okay somebodys gotta get these.....
they keep sitting on my desk
if nobody wants em I'll just send the to this guy:
http://www.youtube.com/watch?v=lAl28d6tbko
if they were white id take them off ur hands
Old Feb 16, 2012 | 02:50 AM
  #1162
Scion202's Avatar
they are white! they are cool white 6000k
Old Feb 16, 2012 | 03:11 AM
  #1163
Scion202's Avatar
my version of autoX
Old Feb 16, 2012 | 03:12 AM
  #1164
1293RS7's Avatar
my daytime running lights are white and i dont think they will match with the cook white
Old Feb 16, 2012 | 04:10 AM
  #1165
MightyP's Avatar
Haha, that's a pretty cool video.
Old Feb 16, 2012 | 08:07 AM
  #1166
Scion202's Avatar
thanks guys
I will plasti dip em first and see how it looks. If it sux, it will be removed momentarily
Those are just on, I haven actually tested if it rubs or not
Specs:
Wheel Brand: Rays Engineering (Forged)
Wheel Bolt Pattern: 5x114.3
Wheel Size: 19x9 (front), 19x10 (rear)
Wheel Offset: +47 (front), +30 (rear)
Wheel Weight: 23.2lbs(front), 23.9lbs(rear)
Hub Bore: 66.1
Price per new rim: $950
Tire Brand: Bridgestone (RE050A)
Tire Size: 245/40/19 (front), 275/35/19 (rear)
Tire Weight: 29lbs(front), 32lbs(rear)
Price per new tire: $350
and black looks sick!
I found a good deal on tires on ebay. This also means that rolling diameter and weight of tires will be closer to stock
Instead of using:
I'll be using:
Tire Size: 235/40/19 (front), 245/40/19 (rear)
Tire Weight: 26lbs(front), 29lbs(rear)
so im taking the fronts that wheels came with and throwing them on the rears
rears will be slightly stretched cuz tires are spec'ed for up to 9.5"
but also I will be removing 12lbs by taking out 275's for 235's
total stock tires(96)+wheels(108 ) = 204lbs
new setup tires(110) + wheels(94.2) = 204.2 lbs
Old Feb 18, 2012 | 10:13 PM
  #1167
biglilsteve's Avatar
Love it!
So why are you using extended bolts?
Old Feb 18, 2012 | 10:35 PM
  #1168
Scion202's Avatar
haha love what?
the rule is to have at least as much thread as the width of the bolts
so since we have 12mm bolt, i need at least 12 mm of engagement
with stock wheels we have roughly 19mm on usable thread
with Nissan Rays I had only ~16mm of engagement
its all fine still but I want to use 5mm spacers to make the offset 42 instead of 47
with spacers I only got 10-11mm of engagement and only 9mm with the wheel lock because it is shorter
changing them looks simple enough
https://www.scionlife.com/forums/sho...70&postcount=1
Old Feb 18, 2012 | 10:41 PM
  #1169
I love that you have a new setup with bigger wider sexier wheels that weighs equal to stock. Well before you add spacers. For 5mm should be negligible anyway.
Old Feb 19, 2012 | 12:10 AM
  #1170
Scion202's Avatar
thanks man
I cant wait to put em on/for winter to be surely over
Im thinking just putting them on asap and put snow on whenever the weather is expected to be crappy
the 235/40/19 tires and hub rings are coming on tuesday so I may be test driving new wheels next weekend if the weather allows...
Old Feb 19, 2012 | 03:53 PM
  #1171
P1MP5QU4R3D's Avatar
Love the blue lighting
That is what I want for my XB
How hard was it to do the mod? Or did you have help?
Old Feb 19, 2012 | 06:43 PM
  #1172
SoulShinobi's Avatar
Most was done by a local car audio shop.
Old Feb 19, 2012 | 06:50 PM
  #1173
Gotcha
Gots me some research to do then
Old Feb 19, 2012 | 08:25 PM
  #1174
Scion202's Avatar
well it depends what you need help with, Ive taken most things apart to see what they did. Plus i was the one who came up with the ideas and looked into it myself first to see how doable it was
Old Feb 19, 2012 | 09:01 PM
  #1175
Scion202's Avatar
Installed Weapon R intake
My experiences with intakes:
1. Stock
2. Stock with snorkel delete
3. Takeda CAI
4. Weapon-R SRI
Initial thoughts: I was kind of disappointed with the sound. I was expecting a much more agressive RAT-TAT-TAT sound but it wasn't really there. However I do believe I didnt see much difference because I was using stock without snorkel and it by itself adds meaner sound. As a result the difference wasnt as drastic. If you try weapon-r after unmodified stock box then I am sure it will seem like its much much better. If compared to Takeda then it doesnt even come close. Takeda has a very pleasant, mean, and loud sound that overpowers the exhaust. In quieter car, like my roommate's Corolla, you can hear the intake over everything else but its not really the case with tC2.
Performance:
No questions about it, the intake definitely adds more power starting at about 3.5-4k RPM. I did not notice any power loss in the low range. With Takeda on the other hand, I definitely lost a bit of low end torque. It is kinda hard to compare the 2 because I didnt have a light weight pulley with Takeda. Overall the car feels more responsive and less shy to throw the odometer needle into the red line
Cusco Fitment:
Definately better than Takeda but still not very promising. We dont really know how the the engine moves when we are taking a hard corner while full on stepping on the gas pedal.... I did put some soft heat resistant insulation in the place where it is most likely to contact
Summary: Good power(almost as much as CAI) but without loss of low end torque. Sound is fine from stock but it you ever heard a CAI, it will be a bit disappointing.
Old Feb 19, 2012 | 09:08 PM
  #1176
GAPS11TC's Avatar
Nice review. How do you take out the snorkel on the stock? I wanna see whats the difference.
Old Feb 19, 2012 | 09:47 PM
  #1177
Scion202's Avatar
just take off one screw and pull it out
Old Feb 19, 2012 | 10:48 PM
  #1178
Well this is my first car and it is safe to say that I know nothing.......
I fix computers, can handle most construction projects (except electrical), but I know no more than the basics when it comes to cars.
So with that as a starting point..............
Old Feb 19, 2012 | 11:11 PM
  #1179
Scion202's Avatar
alright well its not hard to just tap into a 12V source...
whats hard is to find the door trigger aka the lights come on when you open the door.
what did you have in mind?
Old Feb 19, 2012 | 11:34 PM
  #1180
Well I want to do the whole interior in blue leds to start
Then thinking doing puddle and accents exterior also in blue
But I want it to all be very clean
