Scion FR-S Forum - The Scion sport coupe
tC -> FR-S.....and I am back!
Old Feb 20, 2012 | 12:11 AM
  #1181
Scion202's Avatar
Originally Posted by P1MP5QU4R3D
Well I want to do the whole interior in blue leds to start
Then thinking doing puddle and accents exterior also in blue
But I want it to all be very clean
okay, so what do you want to do first? ask me any questions regarding that I will try to help/make a video if it hasnt been already posted in here.
clean LED install means that they should not be visible....thats it
Old Feb 20, 2012 | 02:31 AM
  #1182
P1MP5QU4R3D's Avatar
Where to start?
What's the easiest?
Overhead lighting?
Old Feb 20, 2012 | 03:54 AM
  #1183
GAPS11TC's Avatar
Originally Posted by Scion202
just take off one screw and pull it out
Sweet! Thanks bro appricate the help!
Old Feb 20, 2012 | 04:07 AM
  #1184
Scion202's Avatar
Where to start?
What's the easiest?
Overhead lighting?
well obvi to replace the existing bulbs is easy. u got front and rear domes and the trunk lights. i use superbrightleds.com and they never failed me
Old Feb 21, 2012 | 09:52 PM
  #1185
Scion202's Avatar
Stock Air Box without snorkel vs Weapon R intake
Stock
Weapon-R
Old Feb 21, 2012 | 10:01 PM
  #1186
biglilsteve's Avatar
I need a place like that to play around! Where is that?
Old Feb 21, 2012 | 10:06 PM
  #1187
Scion202's Avatar
haha thats where i work
huge parking lots too....no snow though to play around
Old Feb 22, 2012 | 02:33 AM
  #1188
Red face
Ok, thanks
I'll check them out
In looking around I've seen alot of different kinds of LEDs
Is the effect of the sheets as dramatic as it appears in the pictures?
Also, how hard is it to setup a toggle for "all on/off"?
Old Feb 22, 2012 | 02:38 AM
  #1189
GAPS11TC's Avatar
There really is a different sound, I never thought that intakes really make a difference. I like it! Lol
Old Feb 22, 2012 | 04:26 AM
  #1190
Scion202's Avatar
Ok, thanks
I'll check them out
what do u mean effect of the sheets??????
of course not, putting a switch is is a joke. just put it on the positive wire so it either opens or closes the circuit
haha i just barely listened to videos myself . yeah you can hear the engine sucking in air and its meaner sounding(not as mean as a CAI!) but it does overpower all the belts and other crap you may hear coming from under the hood
Old Feb 22, 2012 | 03:57 PM
  #1191
I am refering to the LED sheets for the dome lights
Most if the pics that I have seen using the sheets appear to have a much more dramatic effect, not necc brighter.....Just more aesthetic. More of a "glow"
As far as the switch goes, I am talking about a toggle for ALL of the interior lights. Something that would be like a bypass. Allowing you to turn them all on while the car is off.
Old Feb 22, 2012 | 04:37 PM
  #1192
Scion202's Avatar
those sheets are called PCB boards. they do add an interesting look. I believe I have a 24-led one and some ppl are shoked to see 24 little individual lights.
blue lights in general dont produce a lot of light because the higher the temperature of the color the more your pupil contracts. That is part of the reason y using 10k aka blue HIDs is useless because you cant see anything with them. If you do get really bright front dome lights you still wont be able to tell the difference in some colors and at times it may give you a head ache. im replacing my front domes with cool whites as soon as i get a chance. everything else will stay blue
if you want a toggle switch for Dome lights then that's a big NO inless you get it done right/professionaly. When addin a power source to something that already has one you have to use a relay in order to avoid a huge disaster of burning out your electrical system. If you turn on the domes when the car is off and then start the car....____ is gonna blow.
If you wanna add a swithch to additional lights such as puddle/grille/speakers then its totally fine just make sure to use a fuse because you may have to connect directly to the battery unless you can find a constant 12V on the inside's fuse box, which is prolly not that hard if you just used a multimeter and poked around
Old Feb 22, 2012 | 05:19 PM
  #1193
Scion202's Avatar
actually you could use 2 switches. one on/off and the other 2 pole or 3 pole switch for selecting the sources
BTW!
dome is already connected directly to the battery! why am I explaining all this haha
WHICH MEANS YOU CAN JUST TAP INTO THE DOME! I DID A DIY IN HOW TO DO IT IN MY THREAD
Old Feb 25, 2012 | 10:07 PM
  #1194
Scion202's Avatar
While waiting for my new tires to be mounted i saw this:
so now I have Max Performance Summer Bridgestone Potenza RE050A tires on
235/40/19 on the 9" fronts
245/40/19 on the 10" rears
Rears are stretched 0.5"
Since I got it done at Costco, they inflated them with Nitrogen which is why the caps are green
Rear 10" stretched
Front 9"
On left is Rear and on the right is Front:
(rear looks meaner because of the lower offset)
oh yeah and I installed the front mud guards only because i dont have time to do rears.
fronts are wicked easy to install. you dont need to take off the wheel. I did anyway but all you really need is a flexible adapter
EDIT:
Tires arent new haha, each costs like $350 new!
245s came with the purchase of the wheels and have 65-70% thread left
235s I bought on ebay for $130/pair - they look ____ty and have little cracks all over and have ~60% thread
Old Feb 26, 2012 | 12:09 AM
  #1195
GAPS11TC's Avatar
B E A UTIFUL!!!
Old Feb 26, 2012 | 06:33 AM
  #1196
johndeo11's Avatar
i just saw the wheels on a 370z in a park. i was like, "WHOAH! it's more beautiful than in pictures!"
Old Feb 26, 2012 | 06:35 AM
  #1197
Scion202's Avatar
they really are, from far away they look a bit weird but up close
B E A UTIFUL!!!
thanks, the tires are ____ though...will not pass inspection
Old Feb 26, 2012 | 11:44 AM
  #1198
jtk2's Avatar
Lol. I just saw them too! Some 370 was parked in a parking spot. And yes wheel look Amayzing in person!
Old Feb 26, 2012 | 09:53 PM
  #1199
johndeo11's Avatar
mount the new wheels now! lolz i wanna see what it looks like on tC2... :D
Old Feb 26, 2012 | 10:06 PM
  #1200
Scion202's Avatar
^ u r so in luck haha wait a couple mins
