AEM 2AZ Fuel Rail
AEM 2AZ Fuel Rail
AEM High Volume fuel rails feature a 1/2-inch fuel bore to support fuel flow for applications up to 1,000 horsepower. This large bore also dampens backpressure pulses created by larger injectors and works perfectly with stock injector sizes. An additional 1/8th NPT port is included to accommodate a nitrous set up or fuel pressure gauge. A custom fuel line fitting is included for the factory fuel line, and the ends of each rail are pre tapped to accept -6 AN or 9/16”x18 fittings for users who want to use custom fuel lines.
Part #25-170BK
Description: High Volume Fuel Rail
Application: 08-10 Scion tC, 08-10 Scion xB
Dims: 16X3X3
Weight: 3lbs.
http://www.dezod.com/pd-aem-high-vol...10xb-08-10.cfm
Part #25-170BK
Dims: 16X3X3
Weight: 3lbs.
Threequalseven
08-26-2015 04:24 PM
