Scion xA & xB 1NZ CR-Lite Crank Pulley From NST
MORE INFO HERE http://www.nonstoptuning.com/pKitToySciXAXB.htm
The NST Lite series is a designation used for pulleys that are light-weight versions of their OEM counterparts. All NST pulleys are built using High quality 6061-T6 aircraft aluminum and are easily 60% to 70% lighter than steel or cast iron OEM pulleys.
The NST Lite series is designed for owners looking to reduce weight and increase the throttle response of their engines. These OEM-diameter Crank Pulleys will neither underdrive nor overdrive the associated accessories but still lead to great throttle response and improved horsepower numbers in many applications.
Each NST 1NZ-FE Kit is carefully crafted from 6061-T6 aircraft aluminum, tested and balanced to high tolerances. Every NST pulley is hard anodized for exceptional durability and is a great item for use at the track or on the street. Available in your choice of colors: Red or Graphite Gray.
BENEFITS:
Great weight reduction
- Average of 60% - 70% lighter than OEM
Increased horsepower
- Average of 6- 8 horsepower
Lower ET's & higher trap speeds
- Average of .20s & average of 2MPH
NST NonStopTuning
Web: www.NonStopTuning.com
Phone: 281-917-0221
AIM: NSTonAIM
MSRP: $125
WEIGHT: 12oz
COLORS: Red & Graphite Gray
In stock and ready for immediate shipping via USPS Priority Mail.
The OEM Scion belt is compatible with your 04-06. You will not need to change to a shorter belt.
Our CR-Lite Crank Pulley is IN STOCK and ready for immediate shipping.
Call within the next 24hrs and I will throw in a FREE NST shirt!
