LCD Reversal
okay... blah blah.. i'm not responsible if you mess up.. blah blah.. legal tidbit... said... done.
best method would be to completely replace the filter with a new one that has adhesive on it... but those filter sheets cost alot of money..
so.... we're just gonna reuse one in this diy, k?
oh and yes.. this can be done to ANY LCD screen.. my old calculators... the HVAC.. the uhm... yeah. whatever
first step... take out whatever from car (i.e. gauges in diy)
you don't have to take apart the gauges completely (as in the board and such... as i did in the pic..) but as long as you get to lcd.. you're good..
so.. second step... where it begins... take prying instrument (i.e.. razor blade)
aim downwards and get under that filter..
pry a little bit more (NOTE:.. do aim the blade downwards... the filter CAN get scratched.. so take it easy..)
you don't really have to do too.. much... once enough... you can grab the filter and peel off the rest.. make sure not to angle it too much either... crease in filter... hmm.. bad? ohh and do support the lcd itself... it's glass afterall...
now.. to be able to reverse the LCD, the filter needs to be flipped around.. all that adhesive crap that was on there? it needs to be removed... cause that side is going to be facing outwards now... so... use adhesive remover of choice... and soak..
blah blah... clean all that crap off... and on the lcd too.. sure...
and place it back on.. (maybe tape the edges down..) and voila!
Originally Posted by Runawayrogue
What kind of adhesive you using to put it back on?
hmm.. a small piece of tape at the edges will hold it in place and you wont see it after you place the gaugeface back on.
Originally Posted by Keeshwah
Any pics of this without an led swap? I wanna get something to be black background with white numbers like my alpine HU.
So it's just a plastic layer? I was assuming originally that it would be like a laboratory slide, with two panes of glass. Maybe I should dig out one of those el-cheapo calculators I always get for christmas (I have a TI-89 as well as a PalmPilot with a program that works like Matlab) and try this out.
What's being flipped here is the front polarizing layer. Was it flipped "top-to-bottom" or "right-to-left"?
Originally Posted by titolito
Originally Posted by no-tec
you have very nice nails for a man
Yes, Trung is a sexy bi+ch!
Originally Posted by dmyers03
you said the filter sheets cost a lot of money. ok, if somebody happens to break one, where do you get another one from and about how much would it cost? or do you just have to buy a whole new lcd unit?
or sacrifice a calculator...
