All Your Motor Oil Answers
#141
Originally Posted by Whyspeed
If you using syn. in a brand new car your wasting money! for a high mileage car, yes... brand new car, no! it doesn't hurt to use syn. but i would not use it in a brand new vehicle. your just wasting money. if Toyota recommends 5w30 then go with it.
___
#142
Isn't 0w-20 a little too thin? Even though I live in Cali where it doesn't get too cold.
__________________
__________________
#143
Originally Posted by ThisDudePaul
Isn't 0w-20 a little too thin? Even though I live in cali where it doesn't get too cold
It's even better for those who live in cold areas.
It's the number of the oil before the car is up to operating temps.
The important number is the 20.
It's the right number too!
#145
Originally Posted by GammaTNT
I heard 2006 and newer tC use 5w-20
Should my supercharged 2006 tC using 5w-20 too?
I got my tC since May 2005.
I'd use synth on the SC.
SB
___
#148
Originally Posted by xsupermario
I got an 09, on the cap it says to put 5w-20 but i have some rp in 5w-30 in the garage. can i just use that instead?
Will it harm the engine?
Likely not.
But, they say 5w20, so use 5w20.
SB
#151
Is there a reason no stores carry Royal Purple Max ATF? I looked 3 diff stores.
Kragen had 4 bottles and they don't stock it any more. Does it suck or something?
__________
__________
#152
#154
Noob here. Just read the entire thread. Thanks everyone for all the great info. I'll add one thing: If you can, do your own oil changes because you'll know that everything that was supposed to be done was done. Dealers, Walmart, Jiffy, etc., have all been caught cutting corners by not doing the things they tell you they will do. It has happened to me enough times that I finally decided to never trust my vehicles to these places. First time it happened was in Spokane. I went to Walmart and got their top oil change/service on my truck. What they didn't know was that I was taking it from there to Jiffy to have the differential serviced (Wally doesn't do that). Jiffy found that the fluid in the diff was so burnt they had to flush it three times. They didn't charge me any extra for this, so there was no motivation for them to be messing with me. The tech said he could tell that no one had checked the diff recently. He also told me that he used to work at that Walmart and they routinely cut corners to get cars in and out. I went back to Walmart and told them what I had learned. They apologized immediately, refunded my money, and gave me a certificate for a free service in the future. It was clear this wasn't the first time someone complained about their practices.
So I stopped going to Wally and switched to Jiffy. Many years went by and then I started having transmission problems with my Volvo. The car had an oil change at jiffy two weeks before this happened. The first thing I did was check the fluid level in the transmission. It was fine but it was also total sludge. I drained it and pulled the pan and the transmission was beyond hope. This didn't happen in two weeks and I suspect it didn't happen in two years. If so, that would mean that this particular Jiffy Lube supposedly checked the transmission at least five times without telling me what they were seeing. My guess is they never check it.
When I was younger, I used to do everything on my cars and I never had problems like these. Life got busier, and the cost savings for DIY maintenance got smaller, and so I just turned everything over to the so-called professionals. My advice: if you have to use them, don't trust them. Make certain they do everything they are supposed to do by either watching them (Oil Can Henry's) or checking things after they get done. As for me, I'm back to doing it myself. Also, it may just be me, but there is a certain satisfaction that comes from getting you hands dirty now and then. Smelling like oil for a good part of the day is somehow an added bonus. So you end up saving a bit of money by DIY and then you get something that money can't buy as a reward.
__________
__________
#157
I am going to switch back to conventional oil, since I don't have supercharger on my tC anymore.
__________________
#159
Does anyone know if the latest '18+ Castrol Syntec , 0w-20 or 5w-30 , is that lower grade base oil , some posters here were speaking of 8 years ago ? Any additional info on Castrol synthetic oils ?
LavaBox_v1
65
04-21-2005 01:44 AM
