car starts to bog after certain rpm levels
I got a 06 Tc, and its starting to bog out in every gear after 3000 rpms. If I slowly push down on he gas it will drive OK until I hit 3k. If I hit the gas to hard the car bogs and I doesn't want to move. I would have to wait till rpms go down and then I can proceed. This is in every gear I put it in. I do have a check engine light on. Codes are mass airflow sensor and left and right rear speed Senors. My mass air flow senor is only a couple months old but either way I took it out and cleaned it.
Also when I start the car right away it will turn over and start but right away turn off if I have the key clicked twice so all electronic components are on wait a couple seconds then it turns on fine.
Note: this all started after I disconnected my battery because my hid bulb went out.
cid_mcdp
01-05-2015 02:45 PM
