check engine code P0340, P0340(pd)
Old Dec 3, 2012 | 11:00 PM
rican_lunatic's Avatar
Default check engine code P0340, P0340(pd)
so im throwing two code of P0340, P0340(pd) on my tc. I thought it was the cam position sensor nd I bought a new one replaced it and its still throwing the two codes. the car starts some times right away and some times it starts after 2 or 3 cranks. the car back fires when i shift 1st to 2nd nd sometimes to 3rd gear. Any ideas of what other things i can do?
Old Mar 20, 2013 | 12:59 AM
Bump
Old Mar 20, 2013 | 01:07 AM
LSBoogie's Avatar
Streched chain? Crank sensor? Any associated rattling from engine?
Sent from my SCH-I535 using Tapatalk 2
Old Mar 20, 2013 | 02:39 PM
There is a little rattle sounding like from the top side of the head but not dramatic about it. Stretched chain never herd of. Nd if it was the crank sensor wouldn't it threw a different code instead of cam position sensor?
Old Mar 21, 2013 | 01:13 AM
LSBoogie's Avatar
If your chain is streched you will usually hear rattling from the engine. Chains can strech over time or mist commonly due to lack of oil changes or low level. If its streched you will get cam timing codes because the sensors can't communicate in time. I don't know much about these particular engines but I've seen a crank sensor that was dying trigger cam codes.
Think you might need to take it to the dealer and have them diagnose it.
Old Mar 23, 2013 | 09:56 AM
jct's Avatar
jct
how many miles is on your engine?
Old Mar 23, 2013 | 04:13 PM
Since I blew me motor I got another one but they told me it had 30k on it.
Old Mar 31, 2013 | 11:47 PM
BUMP!!
so far i've been told i need to switch the timing chain on the motor (which i want to stay away from) due to the fact i took out the motor once i really dont want to do it again.
now ive been told maybe it could be the timing tensioner. bbuuttt i was doing some homework nd seen on other sites that you have to change both the timing tensioner nd the chain to eleminate the rattle noise thats on the side.
whats going on in the motor:
rattle noise by the pulleys
loss of power while driving
check engine code which is cam position sensor(i put a new one in nd code still there)
some times car starts right away and some times it takes 2 or 3 times before starting.
any other observations before i start tearing this motor apart??
daniinpitt
Apr 4, 2015 08:07 PM
tersmurf
Jan 16, 2015 11:34 AM
greytc
Jan 12, 2015 09:49 PM
AdmirN
Jan 5, 2015 10:19 PM
rcflyer15
Dec 5, 2014 05:15 PM
