Gear OIL requirements
you guys that have yout TC's already.. is there any mention in the manual as to what is the recommended gear lube weight and capacity for the 5sp..
u mean transmission fluid?
well.. yes and no.. id like to know what they recommend for the 5 speed gear box.....
usually.. transmission fluid in my book refers to automatics transmission fluid.. gear lube usually refers to lube used in the stick transmission.. :P in a manual. they should make a differentiation between the 2... i hope.. |
Well, it's a transaxle, so the transmission shares fluid with the differential. Anyway, the shop manual says viscosity SAE 75W-90, grade API GL-4 or GL-5. It takes 2.5L or 2.6 US quarts.
cool.. thanks jason...
