Where is Transmission Gear Oil Drain Plug?
Can somebody post a picture or specify where Transmission Gear Oil Drain Plug, Fill Plug and Dip Stick is on Scion tC 5 speed Manual/Standard Transmission.
Here you go, the part number highlighted in blue is the drain plug and the part number labeled 33101A is the fill plug. There isn't a dipstick on a manual transmission.
http://scinergyia.com/modules/galler...7/tctranny.jpg -Alex |
Thanks alex for the pictures, can you also tell me the location of the Standard Transmission on Scion tC, when you open the hood, I tried to spot it the other day had no luck?
I want to swap out the tranny fluid for Red Line MTL, which I'm told is very good. But looking at that picture, I can't really translate it to where on the tranny it is in real life. Any one that has done it have a real picture of where the fill and drain plugs are?
Sorry, been away at the Scinergy Meet in the Middle out in Colorado and have had very limited internet access.
Your transmission is located in the left portion of your engine bay. It faces "sideways" like your engine. Basically, look underneath your stock airbox and the silver thing is your tranny. Toyota/Scion doesn't have really good pictures (or any at all really) in my parts catalogues of complete systems otherwise I'd post something, but you should be able to find it if you look where I described above. If you're having trouble, PM me and I'll do what I can. -Alex |
| All times are GMT. The time now is 07:10 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
