Complete scion tc turbokit
hello i have blown my motor and right now in need of the money to rebuild it
i have a full custom turbo kit for sale i would like 1100shipped 950 shipped without aem fic -Cast Iron manifold -Oil and Boost gauges -57mm turbo with .63 turbine -Custom 5bolt downpipe with spipe -wastegate with both 10psi or 5 psi spring -FMIC and piping -Bov -all tbolt clamps and couplers. - oil lines -aem fic(no harness) -550cc injectors - basemap NO PART OUT open to offers i made 272 hp on ptunings dyno at 10 psi and 312hp on a dynjet at infinite motorsports pics the last pipe nearest the throttle body will be replaced with that of a better one http://sphotos.ak.fbcdn.net/hphotos-..._7416162_n.jpg http://sphotos.ak.fbcdn.net/hphotos-..._3734712_n.jpg http://hphotos-sjc1.fbcdn.net/hs510...._2154887_n.jpg http://sphotos.ak.fbcdn.net/hphotos-..._6194468_n.jpg |
that sux man good luck...
What brand WG and turbo? Just might help it sell. GLWS!
did this turbo blow your motor or you did it
^ good question
^^ that's what i was wondering too :eyebrow:
^^^ was also wondering
Originally Posted by my06tc
(Post 3565369)
It isn't a turbo kit that blows the motor, other things have to be taken into consideration such as proper tuning, the condition of the motor before boosting it, fueling, boost/vac leaks, oil deprivation, detonation, etc. The turbo kit, in and of itself, did not blow the motor...GLWS!! |
the turbo itself wasnt what blew the motor as turbos cant do that unless they saend debris into the motor, the motor blew due to detonations over time
950 for the kit with out the aem fic
IF you ever do part out, hit me up about those injectors
a turbo can blow a motor if u are not tuned and try to run to much boost which will cause u to blow stuff
Originally Posted by Robear17
(Post 3566049)
lol still in that case it wouldnt be the turbo in its self it would be you runnign untuned which will cause high egts, detonation, and melt or break something, and turning up boost will make hella power which will break a rod =] |
I can have the money in like 3 weeks.If you still have it,i think i will take it.
my threads on my turbo are messed up would you sell just the 5bolt housing and will it fit a turbonetics turbocharger with the same ar?
sold!
