FS: Brand New TRD SC w/ shaft & 9.5 psi pulley
Hey everyone,
I've got a brand new, never used TRD Supercharger w/ used shaft and NST 9.5 psi pulley for sale. I had bought this TRD Supercharger for my 06 tC as a spare, in the event that my current one would ever fail on me. This S/C was sold to me by a fellow scion member who bought the kit new, decided to go turbo instead, used whatever he needed from the kit and sold me the rest. I'm asking $750 shipped, for everything. I'm selling because I need funds for a new project, my 06 zx6-r. Shaft was used only for a few days because I needed my car running while I upgraded to the custom S/C shafts that were made by Gompka. Paypal preferred. I'm located in Queens, NY. If interested, email me at N0AuTHoRiTy@hotmail.com or PM me. -Terence- |
So the shaft and bearings have been replaced already? What's missing from the kit?
You said someone used what they needed and sold you the 'rest' of the kit. |
hmm im pretty interested in this, im in queens too. installation included? :P lol
It's not the whole kit. This is just for the supercharger compressor, shaft, and pulley. This would be ideal for someone who already has the TRD kit installed and is just looking for a spare supercharger.
what would be needed after getting this?
Originally Posted by Jpac175
(Post 3805092)
TRD, Supercharger Compressor Housing Bracket Replacement Part PTR01-21054 TRD, Emblem, "Supercharged", Plastic Blister Type PTR01-3500E-MB TRD, Emblem, Small Rectangular, Plastic Bubble Type PTR01-3500T-RD TRD 2.4AZ S/C, Cold Plug Replacement Part PTR24-21050-00 TRD, Spark Plug PTR24-21055-01 TRD 2.4AZ S/C, Rear Bracket Replacement Part PTR25-21060 TRD 2AZ S/C, Drive Belt Replacement Part PTR30-21060 TRD 2.4AZ S/C, Wire Harness Relocation Kit Replacement Part PTR41-21050 TRD 2.4AZ S/C, Bracket Kit, AC Hose / Wire Harness Relocation Replacement Part PTR41-21051 TRD 2.4AZ S/C, Oil Feed Line T-Adaptor, AN to NPT Fitting, ByPass Valve Tee Replacement Part PTR41-21052 TRD 2.4AZ S/C, Idler Bracket Bolt w / Oil Return Line Hardware Kit Replacement Part PTR41-21053 TRD 2.4AZ S/C, Valve, Bypass Replacement Part PTR41-21054 TRD 2.4AZ S/C, Air Box Assy Kit Lower w/inlet Adaptor Replacement Part PTR41-21055 TRD 2.4AZ S/C, ECU Remap Module Replacement Part PTR41-21056 TRD 2.4AZ S/C, Crank Position Sensor Wire Ext. Assy. Replacement Part PTR41-21057 TRD 2.4AZ S/C, VSV Rubber Mount, VSV Hose & Bypass Valve Hose Kit Replacement Part PTR41-21058 TRD 2.4AZ S/C, Hose, Oil Feed Assy Replacement Part PTR41-21059 TRD 2.4AZ S/C, Rear Mounting Bracket, assembly, Aluminum Cast Replacement Part PTR41-21060 TRD 2.4AZ S/C, Crankshaft Bolt Replacement Part PTR41-21061 TRD 2.4AZ S/C, Idler Pulley Replacement Part PTR41-21062 TRD 2.4AZ S/C, Driven Pulley w/Hardware Kit Replacement Part PTR41-21063 TRD 2.4AZ S/C, Air Box Rubber Mounts & Sleeves Replacement Part PTR41-21064 TRD 2.4AZ S/C, Driven Pulley Shim Asst. Kit Replacement Part PTR41-21065 TRD 2.4AZ S/C, Clamp Kit Replacement Part PTR41-21066 TRD 2.4AZ S/C, Idler Pulley Hardware Kit Replacement Part PTR41-21067 TRD 2.4AZ S/C, Inlet Cover Replacement Part PTR41-21068 TRD 2.4AZ S/C, O-Ring, Supercharged tC Replacement Part PTR41-21069 TRD 2.4AZ S/C, Oil Pan w/ Return Tube Replacement Part PTR41-21160 TRD 2.4AZ S/C, Thermostat, 70C / 160F Replacement Part PTR41-21161 TRD 2.4AZ S/C, Formed Fuel Line Assembly Replacement Part PTR41-21162 TRD 2.4AZ S/C, Fuel Injectors, High-Flow Replacement Part PTR41-21163 TRD 2.4AZ S/C, Gasket, HC Trap Holder, Buna Replacement Part PTR41-21164 TRD 2.4AZ, Supercharger Main Assy. Replacement Part PTR41-21165 TRD 2.4AZ S/C, Insulator, Exhaust: Stamped Replacement Part PTR41-21166 TRD 2.4AZ S/C, Hose Kit: Inlet/Outlet/Bypass Replacement Part PTR41-21167 TRD 2.4AZ S/C, Hose, Water Return Replacement Part PTR41-21168 TRD 2.4AZ S/C, Oil Return Hard Line Assy. Replacement Part PTR41-21169 TRD 2.4AZ S/C, Rear Bracket & Inlet Cover Hardware Replacement Part PTR41-21170 |
im interested, just funds are a little tight for me right now, would love a spare blower to have ready when the one i have on starts to crap out, which it has started too =\
-what yr is this supercharger?- is it 05-06 or -07 and up
It's an 05-06. But it will fit 07 and up ONLY if you have an aftermarket header or swap out for an 05-06 exhaust manifold.
-well more interested in the blower just to have a spare, so its pretty much stock, no upgrades beside the pulley?
Yup, there are no upgrades to it besides the pulley. Blower has never been installed.
-highly interested now-
Originally Posted by SoulXquisite
(Post 3818857)
waiting on stimulus =\, give me a bit o time
Bump
Bump
BUMP. Willing to part out supercharger compressor housing, shaft, and pulley separately. Make an offer.
I've sent to you
-sent you a message, ooo i hope i get it =)-
PMed you back, SoulXquisite.
