tC: Sold! Taylor Cable Battery Box - Relocation Kit
Update: The two studs that hold the box to the chassis aren't that long anymore. I cleanly dremeled it to me it shorter. This should not cause a problem as the original studs were unnecessarily long and was required to install the kit on the TC.
I only have the leftover 2 gauge wire which is about a yard long. Not long enough for the relocation to the trunk, but I will at least include it. I can't seem to find the actual 2 gauge wire I used to relocate, sorry. I will include however, the battery ground tap that I used which is basically a 2 foot 2 gauge wire that has the battery tap for a negative terminal and a large ring terminal on the other end. This will allow you to ground the battery in the trunk properly. Will also include a fuse connector that can connect the 2 gauge wire. It has a meter on it as well.
Will update first post. Thanks for reminding me. So the sale will basically include everything you need to relocate besides the extra 2 gauge wire. Sale comes with the complete battery relocation box and some parts to do the relocating.
Sorry for the unprofessional photo. I work a lot and when I get home I am just too tired sometimes. However this should be good enough to let you know what you are getting. In the picture you will see the leftover wire. This is the same 2 gauge wire I took off the car actually. Its about 4 yards. I think it might be long enough for you. Disregard the tool bad and dumbells. I don't have a lot of garage room because of my Gram Lights that I'm trying to sell.
Box includes:
-leftover wire
-plastic wire covering
-fuse connector
-decal
-battery mounting kit
-battery box mounting kit
-venting hose
Box includes:
-leftover wire
-fuse connector
-decal
-venting hose
wiltonhall
Jun 23, 2025 10:09 PM
DJ_FroZone
25
May 30, 2019 07:17 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
hampton1100
May 28, 2015 07:32 AM
