tC2: 20mm Eibach Pro-Spacers
(2) Eibach 20mm Pro-Spacers
- 60mm Center Bore
- 114.3x5 Bolt Pattern
These were only on my car for a few days and are in great condition.
These spacers DO NOT require you to replace your studs with extended ones. They bolt right onto your stock studs and then you bolt your wheels to them. Perfect fit, and no other parts/modifications necessary!
Here are a few pics with these spacers and Eibach Sportline Springs
$85 shipped anywhere in the contiguous US.
Let me know if you have any questions!
- 60mm Center Bore
Yup, that's all correct.
These spacers are the type that have their own studs built onto them. They also come with a set of open-ended nuts. So you use the included nuts to bolt them onto your car's factory studs, then you use your car's factory lugs to bolt your wheels onto spacer's studs.
The studs that are on the spacers are the exact same spec as the factory studs on the car. That's how everything works without modification or extra parts needed...and why I chose them
Check the link below:
http://www.youtube.com/watch?v=LNZhLb_wWhk
These are the exact style spacers I have, and the exact install process
I am actually just planning on using the money for satellite radio lol. It hurt a little after taking them off cuz I got used to the sweet wide stance
Guess ill just have to wait til I get new wheels like you.
