SOLD
Hey guys. I just bought these from dqlostsoulz. They are 15mm bolt on spacers just like the ichiba version II. They are hubcentric for the tC1. 5x100.
Reason why i bought these was for the rims i had up until today. Reason why I'm selling is I just sold those rims to pick up a more aggressive pair I came across and do not need these spacers anymore.
Here are some pics from dqlostsoulz. I did not install them. I've had them for maybe 4 or 5 days and counting.
*They are missing 5 nuts. I bought them this way, the other nuts were stripped. So there are 5 nuts in decent shape and the other 5 are in the garbage.*
PM me if you are interested. Thanks for looking! $60 shipped obo. $50 picked up in CT. I will also entertain trades. Let me know what you have. If you are local I'm looking for 18" tires <- and on my end I would add money onto the spacers for tires.
i didnt. i bought them with only 5 nuts. the other 5 were stripped and didnt work. so these need 5 more. i talked to ichiba and you can order new nuts from them, you just have to call them.
idk if you understand how these work. the studs are what you see sticking out. all of those are fine. the spacers slip onto your hub and then you use the nuts you see to connect them to your hub. then you put you wheel onto the studs attached to the spacer and you use regular lugs to attach your wheel.....
all you need is 5 more nuts for the other spacer because the original nuts stripped, the studs are fine.
Studs=bolts
lugs=nuts.. hence lug nuts
u finally made it right on the post above
confusion:
alright man, i thought it would have been clear based on the pictures because all of the studs are clearly there, and that 5 nuts are clearly not there.
my fault though. i edited my original post to make it more clear.
rain7905643
Jun 13, 2018 05:29 AM
