FRS HID Conversion DIY
So before I got a chance to shoot the FRS I posted in photo/video thread, I was able to capture a step by step instruction of how to install an HID kit into the FRS.
Brand: Alumina Xenon H11 6000k http://a7.sphotos.ak.fbcdn.net/hphot...61199291_n.jpg Unplug the factory bulbs, and remove them from the harness plug. http://a4.sphotos.ak.fbcdn.net/hphot...90910411_n.jpg Take the two prong connectors from the Alumina H11 bulbs and plug them into the factory harness plug. http://a6.sphotos.ak.fbcdn.net/hphot...81488659_n.jpg Connect the plugs from the Alumina H11 bulbs to the Alumina S2 ballasts. http://a8.sphotos.ak.fbcdn.net/hphot...61362246_n.jpg Take the remaining plugs from the Alumina H11 plugs and connect them with the remaining plugs from the Alumina S2 ballast. http://a2.sphotos.ak.fbcdn.net/hphot...67019794_n.jpg Turn on your headlights to check if all your plugs are connects properly. If the bulb does not ignite, reverse the two prong connected to the harness. Once you have checked all your connections, and everything is working, use electrical tape to secure the prongs to the harness plug. http://a3.sphotos.ak.fbcdn.net/hphot...54209934_n.jpg Plug the Alumina H11 bulbs back into the factory socket. http://a5.sphotos.ak.fbcdn.net/hphot...86528470_n.jpg Find the supplied zap straps http://a7.sphotos.ak.fbcdn.net/hphot...27256098_n.jpg Zap strap any loose wire and lines to de-clutter your engine bay. http://a1.sphotos.ak.fbcdn.net/hphot...06803232_n.jpg Mount your ballast to a secure location using either double sided tape or zap straps. The ballast was mounted to the frame using double sided tape. http://a2.sphotos.ak.fbcdn.net/hphot...73504429_n.jpg Before and After http://a8.sphotos.ak.fbcdn.net/hphot...55310978_n.jpg |
How's the beam pattern on the wall look like?
By the way what camera where you using? The camera bokeh is pretty nice too. |
couldnt be more straight forward, but that glare isnt great...
Ya but not bad for stock projectors .
crap
Nice, looks pretty OEM. Seems a little more blue-ish than I'd expect 6K to be though.
Do these cars have a squirrel spotter? Kinda looks like it..
Yeah it does. :(
Originally Posted by Yanki01
(Post 4027817)
crap
Originally Posted by doper
(Post 4027982)
Yeah it does. :(
I modded my tC1 headlights way back in the day. That glare above the cutoff goes away. |
