Scion FR-S Horn Problem..
So recently I bought a 2013 Scion FR-S from someone, but when I brought it back to my house and testing the steering wheel horn and it didn't make any sound.
When I press the alarm button on my key fob it worked and I check the rely, fuse, and the wiring behind the steering wheel airbag.
I don't know what the problem, can anyone help me figure this out?
______________________________
Last edited by MR_LUV; Aug 23, 2019 at 01:16 AM. Reason: Moved to Correct Forum by Administrator
The wiring is there but did you check for a short? You can try disconnecting and reconnecting the cable. You can also test the cable's continuity with a multi-meter.
Might want to disconnect your negative battery terminal before disconnecting and or reconnecting any electrical connection.
ScionVIP
Regional - Mid South
Jun 26, 2012 05:44 PM
SEXB909
Apr 26, 2012 05:10 PM
