Scion FR-S Horn Problem..
So recently I bought a 2013 Scion FR-S from someone, but when I brought it back to my house and testing the steering wheel horn and it didn't make any sound.
When I press the alarm button on my key fob it worked and I check the rely, fuse, and the wiring behind the steering wheel airbag. I don't know what the problem, can anyone help me figure this out? *Moved to Correct Forum by Administrator Sticky Where to Post Your Question ______________________________ |
The wiring is there but did you check for a short? You can try disconnecting and reconnecting the cable. You can also test the cable's continuity with a multi-meter.
Might want to disconnect your negative battery terminal before disconnecting and or reconnecting any electrical connection. |
Nope didn't check for any short, but will now.
| All times are GMT. The time now is 10:50 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
