Scion iA Forum - The new stylish Scion sedan
Brake bleeding and engine coolant changing questions
Old 04-21-2019, 01:07 PM
Pariah0x29a's Avatar
Default Brake bleeding and engine coolant changing questions
Need to work on my wife's 16 iA, planning on changing the Coolant, change brake fluid and bleed brakes, and bleed the clutch
EDIT: already bled the brake lines, no problems there
1) where is the engine block coolant drain plug, not the radiator drain plug but the one for the engine block
2) where is the bleeder valve for the clutch? I think it's on the slave cylinder but where is that? An what is the process for bleeding the clutch lines?
Thanks!
Pariah0x29a is offline
08xB714
07-12-2021 01:25 PM
JOHNNYZX10R
09-05-2017 12:12 PM
Luisfc1972
10
02-20-2017 01:10 PM
toolz
10
03-24-2013 05:37 PM
gp1817
09-09-2010 02:54 PM
Quick Reply: Brake bleeding and engine coolant changing questions
