Scion iM Hardwiring Dashcam
I wanted to hardwire a dashcam into my scion iM. I plan on using a hardwire kit from the dashcam maker and on the site it asks for the fuse type. Which fuse type does the 2016 Scion iM use so I know which one to buy?
Also, where is the fuse box to plug in the dashcam located? A diagram I saw on google showed it under the hood while the other showed it under the steering wheel. ATS, ATC, Mini, Micro2 are the ones listed on the site. https://cimg3.ibsrv.net/gimg/www.sci...1de6cbed4c.jpg |
The iM uses low profile mini fuses(far right fuse pictured above), fuse box is located under the dash on the drivers side right behind the OBDII port. This is the fuse box you want to use if you are installing an add a circuit like you have pictured.
Check this video, makes it a bit easier https://www.carcarekiosk.com/video/2017_Toyota_Corolla_iM_1.8L_4_Cyl./fuse_interior/replace |
got it. seems to be working fine so far. Thanks!
