SUPER LOUD HORNS !
SUPER LOUD HORNS !
Well I squeezed them in. You have to pull the front bumper skin completely off. It actually comes off very easily. Six push pins on the top. Snaps in the top corners each side. Remove the front small air dams/flaps or what every the heck they are called. A couple more 10mm screws on the bottom and unplug your fog lights if you have them. Make some brackets to hold them, the ones that are on the horns are junk and can NOT be bent without breaking. Make some solid ones. Mine is a 10" piece of exhaust hanger bracket. And another shorter piece bent at a 90° angle. You will see where the outside temperature sensor is. Relocate it. Then bolt the bracket in that hole. The small (JOKE) horn is bolted near the drivers top area, just remove it. It has one power wire to it. I suggest buying the installation kit they sale with the horn for ease on installing it.
Oh if you test it...... DO NOT HAVE SOMEONE STANDING IN FRONT OF THE CAR ! There is no way anybody will not here it !
BlingSlade
09-05-2015 08:52 AM
