Scionlife.com
Scionlife.com (https://www.scionlife.com/forums/)
-   Scion tC 1G Aero & Exterior (https://www.scionlife.com/forums/scion-tc-1g-aero-exterior-1636/)
-   -   06 tc conversion to projector headlights (https://www.scionlife.com/forums/scion-tc-1g-aero-exterior-1636/06-tc-conversion-projector-headlights-176339/)
Boardspinna Nov 24, 2009 04:36 AM
is it possible to fit newer OEM projector housings (like the ones on the '10) on an '06 tc...and if so, any modification necessary?
thanks everyone :)
Jon Nov 24, 2009 04:37 AM
Yes. For details, search plz. :)
whitetc06 Nov 24, 2009 06:47 AM
yes it will fit fine. Unless your using Hid, you need a diff. harness cause 06 uses 9006 bulbs and the projector uses h11
DJ08tC Nov 24, 2009 07:07 AM
you will need a different harness anyways. You will have to splice a H11 bulb harness in if you want to run the stock halogens. I would be easier to get a 9006 hid kit with h11 bulbs.
Boardspinna Nov 24, 2009 10:45 PM
how would i get a 9006 kit w/ h11 bulbs...??
also can anyone point me in a good direction to get OEM projector housings...i dont want the ebay ones because they typically have a crappy lighting output
DJ08tC Nov 24, 2009 10:50 PM
trdsparks has them but they arent cheap. Whoever you buy the hids from tell them you what you want. They should have no problem sending it out like that.
© 2026 MH Sub I, LLC dba Internet Brands
