Fog lights not working!!!
I just for my tc, so I don't really know much about it. So forgive me If this is a dumb question. My fog lights don't work, why? Are they just for looks or are they supposed to come on?
It could be a lot of reasons. Loose wires, burnt out bulbs, damaged parts. Got to take it apart to find the problem in order to have a solution.
Did you press the fog light button:rofl: j/k j/k ^^^what he said could be multiple things!
1.check if the bulbs are good. a bad bulb will appear foggy or have black burn marks inside the glass capsule and the good bulb will be clear.
2.make sure the connections are making contact 3.check for a blown fuse (usually this is the problem) 4. if you know basic wiring you can check all the wire harness to make sure there are no cut wires or loose connections |
