HELP!!! Turn Signals are not working!!
So all of a sudden my Turn Signals aren't working!! When I push my left, right and the hazard lights, it wont turn on! And when I unlock the car with my keys,
the signals don't flash like it use to either. Does anyone know where i can locate the fuse? I'm guessing its a fuse problem :pray: help me!!!! >_< __________________ |
OWNER'S MANUAL!
open the hood, there is a box on the driver side fender that says "relays and fuses" pop it open, under the lid is a list of which fuse is for what, as well as some spare fuses, and a fuse grabber. |
i was right! found it!! omg AND THEY HAVE SPARE FUSES THAT THEY GAVE ME FOR FREE!!! its like they knew this was going to happen... thanks drax!! *looks where drax is from* ill buy u a drink when u come =P
the real question is, why did your car blow the turn signal fuse? Were you messing with the wiring?
nope... i was driving and all off a suden it just stopped working... weird..
man Thats great
"omg AND THEY HAVE SPARE FUSES THAT THEY GAVE ME FOR FREE!!! its like they knew this was going to happen..."
OMG OMG OKMG:D:D:D:D: how old are u? |
u now omg
This happened to me, my blinkers and hazards quit working. I checked the fuses and they were all good.
I also replaced the Turn Signal Relay part on my tC. Still makes this clicking/buzzing noise when I put on my turn signals or hazards. Also doesn't show up on my dash that my turn signals or hazards are working. All of my taillights, headlights, gauge lights, radio all still work and function. Any suggestions on what it could be? ___ |
Same problem.
Did you find a solution my 2005 Scion xA is doing the same thing?
Originally Posted by ZachVandivort
(Post 4299455)
Originally Posted by Markymark624
(Post 4305613)
Single filament
They are single filament and they are good.
two separate tests needed to determine where problem lies:
1. pull bulbs and directly apply power from jumper cables attached to battery. This bypasses all switches and wiring. Do bulbs light up? 2. measure for voltage at bulb sockets when turn-signals activated. Do you have power at sockets? |
Update! Problem fixed.
Problem solved. It was a screwy flasher.
