Ipod/Sun roof issue 2006 tC
I have searched and searched and have yet to find a solution for either.
First off I am a new proud owner of a 2006 Scion tC. I got it for a really good price and therefore it had a few issues. One issue is I have the AUX plug in on the inside of my arm rest and when I plug the iPod in the noise only come from my front drivers speaker and is horrible quality. Doesn't play the whole things kinda skips through words. I have searched and found I may need a different AUX cord but I have tried 3 that all work on my Alpine in another car. My other issue is the sun roof. It opens just fine, but will not close. When I push the close button it does nothing at all. I spent 20 minutes pushing the button and trying to pull the thing and push the deflector around till it finally came closed. Is this a known issue? What do you guys suggest I do? I want to be able to use the sun roof considering its summer time and car looks awesome with it open. Again I'm sorry if this has been discussed but I have searched and found no good solution for either. *Moved to Correct Forum by Administrator Sticky Where to Post Your Question Sticky How To Advanced Search SL (Scion Life) ______________________________ |
Do you mean it starts to close, then opens again? If so, you likely need to make sure the pivot points on the wind deflector arms move freely and are lubricated. Also lubricate the top of the arms on the deflector (use something like silicone spray or graphite). The sunroof slides on those, pushing the arms down, which is what pushes the deflector down. If it is dry and not lubricated or the pivots are dirty and binding up, it will cause enough resistance to trigger the jam protection on the roof. You also may need to blow out the tracks and make sure they are free of junk and lubricated.
Originally Posted by engifineer
(Post 4006329)
No I mean it does nothing period. It opens fine. But when I push the close button it does nothing. |
I have an issue with my sunroof where I have to push really hard on the button or push it multiple times to make it do anything, is that similar to what yours does?
The thing with your aux, its probably the port that's bad. have you tried the actual ipod cable? did the car come with one? |
Originally Posted by rand0mher0
(Post 4006406)
The thing with your aux, its probably the port that's bad. have you tried the actual ipod cable? did the car come with one? Even when I pressed hard on the button it didnt come. I cant remember what actually finally made it move. It was a combination of lots of button pushing, hard button pushing, trying to mess with deflector and the actual sunroof then it finally came. I dont have the cord that the car came with im just using a basic one i bought at best buy. I have read that they need a specific cord but I have also read the some people bought 5 dollar ones at the store that works. |
Originally Posted by EATJ
(Post 4006467)
UPDATE!!!! I tried it on the way home from work on the open highway and It worked the way it was suppose to. I would push the button it would open some of the way, then again and it would open even more and etc till it was all the way open. Then I would push to close it (while driving) and it would close a little bit (about a fourth) of the way at a time. Then when I got home I would try and close it and it would go almost all the way then open back up. It did this till I held the close button and push the deflector down.
Even when I pressed hard on the button it didnt come. I cant remember what actually finally made it move. It was a combination of lots of button pushing, hard button pushing, trying to mess with deflector and the actual sunroof then it finally came. I dont have the cord that the car came with im just using a basic one i bought at best buy. I have read that they need a specific cord but I have also read the some people bought 5 dollar ones at the store that works. I believe if you look through the owners manual. The built-in jam protection for the sun roof will force it all of the way open and will keep opening back up all of the way when you try to close it until the “jam” is removed. I recommend visually inspecting the tracks for debris and try cleaning/lubricating them and then see if the sun roof will close properly. v/r Connor |
