My Tail Lights NOT working, Pls HELP!
Old Jan 12, 2021 | 10:17 PM
Rodkvth's Avatar
Default My Tail Lights NOT working, Pls HELP!
Hello everyone I just got my 05 tC about a month ago. I'm having a problem with my tail lights. I have replaced the fuse many times but it keeps blowing up.
Also replaced the bulbs because one of them blew out, I got them LED's. I don't know what's going on?
Help, guys!
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Jan 12, 2021 at 10:30 PM. Reason: Moved to Correct Forum by Administrator
Old Jan 13, 2021 | 03:07 AM
JakeAut0's Avatar
Was the car having the issue before you installed the LED's?
Old Jan 13, 2021 | 03:10 AM
Rodkvth's Avatar
Yes, reason I changed them to LED's was because the taillights went off, one of them was burnt so I switched them both.
____
Old Jan 13, 2021 | 03:24 AM
JakeAut0's Avatar
Since the car keeps blowing the fuse, that most likely means there is a short, break, or pinched wire somewhere in the circuit. Check the wires for damage or breaks where the wires could be grounding out. You could try unplugging both tail lights from the white connectors and press the brakes to see if that pops the fuse.
Old Jan 13, 2021 | 02:51 PM
MileHightC's Avatar
Super Moderator
SuperMod
Completely agree that you've got a short somewhere...now you just need to find it.
Old Jan 13, 2021 | 03:50 PM
Rodkvth's Avatar
i unplugged the white connectors in the tailights put a new fuse and didn't blow . Is it the white connector that's bad? Is it the socket? Do I need to replace the tailights or can I just buy the harness/socket? I do not know what it is called to search at the auto parts.
Old Jan 13, 2021 | 03:52 PM
Rodkvth's Avatar
Old Jan 13, 2021 | 05:38 PM
JakeAut0's Avatar
Since it didn't blow the fuse we know that the problem lies in one or both of the tail light harnesses. So remove the harnesses from both tail lights and inspect the wires. You could also have the bulbs in the sockets, removed from the taillight assembly, and turn on the headlights to see if the fuse pops then press the brakes and check if the fuse pops. Move each wire around to see if it pops the fuse. Also, check the bulb sockets for possible corrosion or damage.
Worst case scenario is you buy new tail light harnesses or get some from a junkyard.
Part# {81555-21230} (If you decide to get new harnesses)
Old Jan 14, 2021 | 02:52 PM
Rodkvth's Avatar
We did it you guys! I couldn't find the harness anywhere except the Toyota website and the harness alone was about $40 !
So I just went to a junkyard and got the driver side tail lamp took out the harness and put it into my existing tail lamp and that did it!
Thank you everyone for your help. Glad I joined.
05 tC
___
Old Jan 14, 2021 | 05:01 PM
JakeAut0's Avatar
I'm glad to hear that you fixed the issue.
Old Jan 14, 2021 | 06:45 PM
Rodkvth's Avatar
Thank you!
assassinsmatt
Jul 23, 2020 03:16 PM
WishIhadAtruck
Mar 19, 2019 05:26 PM
ontarioScionxb
22
Oct 23, 2008 12:43 AM
lil_babie_tearz
Regional - Lonestar
Feb 4, 2007 09:09 PM
miraclecreator
Oct 6, 2006 02:50 AM
