Short antenna !! using your OEM antenna !
Here's another way you can use your current antenna to make it short and not loose the reception.
https://www.scionlife.com/gallery/personal/30559_2.jpg |
how'd you do it?
lol yea..what exactly did u do?
All I did was to break the antenna inside the silicone portion, leaving some room inside to insert the end of the OEM antenna witch I also cut about 1 inch from the plastic and then I put some metallic glue (radioshack) inside to glue both ends and maybe fix the receptin on the antena since I basically brke the antenna in two.
Here's a simple drawing. http://tk.files.storage.msn.com/x1pU...da2dKRh75d-V4A |
I just ripped mine apart. We'll see how it works without the glue. :pray:
lol bump.. hows the reception guys??
reception is just the same as before, I used the metallic glue, but it may work different with out glue or maybe not !!
nice, i just did mine. before i just cut it, and painted the tip.
