weight reduction
Besides going CF, getting lighter wheels, and gutting spare tire and seats. Are their any other tricks to do to kill some weight without completely gutting the car and making it looked strip down.
Basically i still want my interior to look good but loose weight at the same time.
Anything i don't know about, or do i basically have it down?
Originally Posted by Wutachampion
lose some weight fatty. jk
i thought i saw someone else ask about this and they wanted to remove the whole moon roof part and make it hardtop style. idk if u kno what im talkin about. but yea tahts all i gots
Anybody got anything else
Remove A/C
Remove all ventilation under the dash
Remove spare tire
Remove everything under the cargo cover
CF hood/hatch/roof
16" RPF1
Shove finger down throat
Btw, your system alone weighs as much as all this stuff.
Remove spare tire
CF hood/hatch/roof
16" RPF1
Originally Posted by CarbonXe
Remove A/C
Remove spare tire
CF hood/hatch/roof
16" RPF1
Remove spare tire
CF hood/hatch/roof
16" RPF1
Odyssey brand battery even with the thicker cables will save some weight. Not to mention it takes some of the weight off the front of the car. My battery weighs around 14lbs.
Lightweight flywheel will save you some rotational mass. Not everyone agrees on them but light weight pulley set will also help a bit.
i agree with carbonxe that it adds weight because of the wires, but yet again you're not dragging the car so reloating the battery to the back will help balance out the weight distribution a bit better. but to lose weight...
TAKE OUT:
passenger/back seats
back panels
carpet
REPLACE:
hood w/ cf
trunk w/cf
roof w/ cf
wheels w/ lighter/smaller ones
battery w/ lighter one
tube frame chasis
you can make the car 2200lbs if you want, but that's some bank...
TAKE OUT:
back panels
carpet
REPLACE:
hood w/ cf
trunk w/cf
roof w/ cf
tube frame chasis
Just remember the more interior pieces you take out, the louder it will be inside. With no seats, rear panels, or hatch panels freeway driving is almost unbearable if you have a non-OEM exhaust.
Originally Posted by Shifty
Mount your battery in the trunk.
TRACTION
The battery's weight is used to help put weight over the drive wheels to aid in traction. Which in most cases is a much bigger problem than actual weight reduction.
Are you trying to get a better E/T on your drag time? If so, don't worry about pulling seats out and all that other nonsense, it is all minimal to begin with. Instead, invest in a LSD, 15" rims and drag slicks for the front. This will help the minimal power get planted to the ground rather than spinning your tires or the lovely case of wheel hop. (also might want to look into poly motor mounts as well as an engine damper)
TRACTION
If you match a tc with a LSD vs the same tc without one and full weight reduction which one do you think will win.
You can have the lightest tC on the forums, but if you can't hook up, suddenly your go-fast diet doesn't mean crap. Unfortunately, most things you can do to lighten your tC will adversly effect another aspect of it, appearance, audio quality, interior noise levels, practical use, whatever. If you want to keep it appearing stock, I've seen an old school charger that had drilled 2" holes into whatever inconspicuous spot in the sheet metal (under the doors, in the jams, under practically every interior panel). Granted, he also used a lot of fiberglass body panels and had no system and just a few interior panels in the car. Just food for thought.
Well if its stock most of the weight is taken out of the back and since its a front wheel drive car all the weight in the front is still the same so i would believe that traction control wouldnt be that much of a difference
You lose a lot of traction with stock set up. And you get A LOT of wheel hop. You can spin almost all the way through 2nd on stock tires and now power mods. And guess what that does for your E/T? I know you THINK weight reduction will help, but the truth is weight reduction only comes in handy when you start to run under 10 sec 1/4's and hundreths of a second comes into play. Cause really, that's all you're gonna gain from gutting your ride. focus on your R/T and hooking up and you'll be surprised at how much you knock off your E/T...
You can be light as a feather and have 1000hp, but it all means nothing if u can't put it to the ground.
