2007 tC Cylinder 3 Misfire - Scionlife.com
Old 10-08-2018, 06:26 PM
Default 2007 tC Cylinder 3 Misfire
I’m getting a misfire in Cylinder 3, have exchanged spark plugs, ignition coils, fuel injectors and ignition coil connectors (they were falling apart).
And still getting the misfire. Anything else I can try?
OBD code is P0303
Sticky How To Advanced Search SL (Scion Life)
How to Turn Off The CEL..How To Diagnose Your Check Engine Light For Free
______________________________
Last edited by MR_LUV; 10-08-2018 at 10:41 PM. Reason: Moved to Correct Forum by Administrator
wkndwrz is offline
Old 10-11-2018, 10:34 PM
alxm's Avatar
Originally Posted by wkndwrz View Post
Iím getting a misfire in Cylinder 3, have exchanged spark plugs, ignition coils, fuel injectors and ignition coil connectors (they were falling apart).
OBD code is P0303
Did you also replace the injector insulators? The new injectors normally come with the o-ring at the top that is used to make a seal to the fuel pipe. But the bottom insulators which are kind of like seals/o-rings do not come with the injectors. They are placed on the engine head where the injectors insert in and make a seal for the bottom of the injector. If there is an air leak because the injectors are not properly sealed between the fuel pipe and the engine head. That can also cause a misfire. The bottom insulators are available at AutoZone for about 5 or 6 dollars each kit. It comes with bottom insulators and the top o-ring, one kit is for one injector.
Lastly it may possibly be the fuel pump. There may be not enough fuel getting to the injectors. But I feel this would affect more than just one injector. As its delivering fuel to the fuel pipe which is feeding all 4 injectors.
alxm is offline
Old 10-11-2018, 10:39 PM
I already fixed it yesterday, but youíre right that was it so they werenít spaced correctly and causing a misfire. So it sounds like the original misfire was the fuel injector after all and then continued because of the insulators. Thanks for your help
wkndwrz is offline
Old 10-12-2018, 12:33 AM
alxm's Avatar
I already fixed it yesterday, but you’re right that was it so they weren’t spaced correctly and causing a misfire. So it sounds like the original misfire was the fuel injector after all and then continued because of the insulators. Thanks for your help
Awesome! No worries. Glad you fixed it. And yes it's usually an injector in my experience. I've had to replace a bad injector and coil on my ride.
alxm is offline
xa007xa
05-04-2009 05:54 PM
thaotc
11
02-03-2009 01:36 AM
dubstyleeca
14
12-09-2007 05:30 PM
HondaKiller
15
10-08-2006 02:46 AM
mtxgalant96
07-19-2006 04:47 AM
Quick Reply: 2007 tC Cylinder 3 Misfire
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
