air/fuel gauge help....
wuts up guys well i just need some help hookin up my air/fuel gague its the autometer pro comp ultralite series..it ahs a red/black and purple wire on the back..my bro had it in his honda but obvioulsy the ecu are different so i didnt know if anyone has this one in the tc or know how tyo wire it up..thanks in advance..
Gauge will not work with the Lamda sensor (wideband) in the header. It will work on the s-pipe sensor but this is pointless unless you have a header that doesn't have a header in it. You need to get a wideband setup.
http://www.nolimitmotorsport.com/prod/PLX-M300
Im looking for a wideband thats good .... and hopefully less then $300. Just a digital readout would be fine. I dont think i need all the colors when its running rich/lean ...ill know what #'s things should be.
Originally Posted by yamaha16bw
The Autometer wideband comes with a a/f sensor. Whats the part # of the gauge?
http://www.jegs.com/webapp/wcs/store...tegoryId=10339
Yeah I thought it came with a sensor. So if you have the Autometer wideband a bung have to be welded in the spipe for the new sensor. You will not be able to tap into the stock sensor.
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
