Alternator not charging battery
Hey guys , im kinda stuck here.. My battery died so i thought it was alternator so i changed it out with a new one and still doesnt charge the battery. The battery is brand new too .. I brought the old alternator in and got it checked and it was actually good .. I also have the brake and ABS lights on my dash and i cant pull it out of park.. My brake light do work though .. I feel its related.. Since its not a bad alternator what should i look for next on why its not charging the battery? I checked the 120v fuse and it was fine.
Check all of the fuses and your grounds.
hellllp
Originally Posted by JoeyBishop
(Post 4168860)
did you ever figure out what was wrong |
So I figured out that the alternator in my 06 Xb went out and so I bought a new one. I got everything disconnected on the old one, wires and bolts but now the old one is still stuck in there. It moves back and forth but it won't come out. Did I miss something?
Originally Posted by wilhelmdla66
(Post 4311155)
There is a nut that tightens in on the back of the alternator when you tighten the bolt to the right torque. The bottom bolt tightening pulls that nut to the mount as a fail safe to keep the alternator solidly in place. Keep rocking the alternator back and forth until that lock nut loosens up. You can also put the bolt back in and try hitting it with a hammer to loosen it up a little but I'd say be careful if you do because you can break something. It'll come out, promise. I just did my factory alternator and that's what I did. Rock it back and forth. You can try the pry bar too since the xB has more space then the xA, but even with the bar you have to get that nut lose. Hope this helps and makes sense.
