Auto Tranny Build Up Guide
Originally Posted by 1slowtc
i have a valve body in my tc and some other things but when i just did the valve body i gained almost a sec in the 1/4 and yes i do feel a diff in letting it shift or just shifting it myself
Strictly Scionized
changed tires to. 14.3 still messin with it and still geting faster best time so far 13.20 no shift light sometimes shift early sometimes late just ordered light today. also ordered a boost controller. ihave time slips of the frist night runnin her just kept getting faster
This might be a noob ? and prolly is, but does anyone know what tranny we have, or if we share one with a different car?Cuz i cant find a specific tranny upgrade fir the tc, or the site just hasnt been updated, any help would be great. Thanks
No, there isn't a specific tranny upgrade program per se, just mainly component parts or a single upgraded item.
Torque converter, internal clutch packs, valve body, springs and actuator solenoids. These are the perennial items to get in order for the tranny to hold increased torque to approx 550Nm.
Help the info helps
It is thanks. Im planning on boosting in the future and i want something that wont fry my tranny, but still be able to hold real well. Would it make much of a difference on an almost stock car if i upgraded? So ill prolly have to get the parts for those model trannys and put them in, and where whould i be able to get the tranny service manual? If its at the dealer ill prolly just pick one up when i take my car in for new brakes. Thanks
So, yes there would be some improvement over stock but its really meant for increased power to justify the cost and labor involved in changing out, mainly TC or SC to beyond 250whp. Another advantage is that you could still brake boost the car on a daily basis and keep everything intact
Gizmo : I would recommend IPT TRANSMISSION for main body works. Torque Converter has to be JMO, the TCon specialist. They are the sole contractor for TRD japan
Ok thats good to know thanks, and how often could u shift the auto tranny before damage is done? And to be clear i mean shifting while street driving by going from L, to 2nd , to 3rd, and D before doing damage
http://www.levelten.com/store/import...shiftronic.htm
Anyone seen or heard of a tc with shiftronic? good idea or bad idea?
If it's the above scenario, your tranny would be intact EXCEPT for the clutch packs which would wear out fast. If you're thinking tranny grenaded.... no it won't the planetary and main sun gear would still be fine. Its your clutches that will burn eventually requiring more often replacements. ATF should be changed out more frequently say every 20k miles if you are going to abuse the tranny like so... You should already have an external stack plated ATF cooler installed when you are at this stage
Proper built auto tranny for 300ish whp? Should last 100k miles easy
Hes prolly talking about the same thing i am. Thanks for the info, but im still pretty much stock, but i should really get the cooler when i get the chance. I dont really do the enegine braking, but i do need new brakes : P, and would i be able to upgrade those pads? Thanks
For rotors, I always recommend slotted only. Forget cross drilled + slots. Gimmicky as they would give you less surface area and this affects your stopping efficiency.
Manually shifting a auto is BAD, I had a friend in a 05 accord go through 2 trans cause he kept doin it. His new trans has lasted 5 times as long since he stopped.
As far as tranny upgrading, if ur not looking to build the car fully and just wanna turbo it, a tranny cooler is good enough. Auto dont put out enough power for the NEED to upgrade, Unless you have some good experience with cars i strongly suggest goin to ipt trans or level 10 or watever reputable trans shop to have these things done.
Good advice nevertheless
Auto sticking an auto is def. not a good idea. It wears away at the tranny a lot.
And wow. I'm glad there's actually responses to my write up unlike at yoursciontc.... :D
dare I go for a sticky with this topic?
