Clutch Problems! Please help!
I have a 2009 scion tC that we just replaced both the clutch master and slave cylinder. The clutch will not come back up off the floor even after bleeding. I bench bled both parts before installation, performed standard clutch bleed more times than I can all of which would show no signs of air once complete. I then gravity bled it for about 4 hrs, started out with fluid only coming out but then ended up having a steady stream of air bubbles for hrs. Absolutely no change in clutch after 4 hrs so I gave up. There are no noticeable leaks anywhere. Any suggestions would be greatly appreciated!! Thanks!!
WRX1316_TcVicent
07-22-2021 06:06 PM
