clutch wont disenguage after upgrade
i upgraded o the act street disc with the xtream pressure plate. is there any issue with the oem slave cyl not being strong enought for the xtream pp or a weird bleading proceduure?
thanks taylor |
you would only need to bleed the clutch if theres air in the lines....but i have the act street disc with the heavy duty pressure plate....the only thing i had to do was ajust the clutch pedal....just make sure you did the install correctly and everything was tightened to specs and aligned,but i know a few ppl with the xtreme pp and had no issues beside getting a exteneded push rod to make it easier to disengage
clutch pedal adjustment is probably needed... if u need more travel on it speed source sell the pushrod you need for the slave cylinder.
got a link to the extended pushrod
also how do u adjust the pedal? |
check out this thread maybe it can help,ajusting the pedal and install of the rod
https://www.scionlife.com/forums/sho...d.php?t=183608 heres the link to purchase it http://www.speed-source.net/ |
