Code P0172..
Old 05-23-2019, 07:30 PM
iiTyran's Avatar
Question Code P0172..
So, My Scion tC 06 is throwing the Code P0172. So I cleaned the MAF and checked it and its not that. I was at the mall and when I came back to my car and it turned on and idled at below 500rpm and then turned off.
So I turned it back on and revved the engine up to like 5k RPMs 3 times and it stayed on. Then I drove it home.
What could it be? Fuel pressure regulator? Fuel Pump?
Any advice?
______________________________
Last edited by MR_LUV; 05-24-2019 at 01:37 AM. Reason: Moved to Correct Forum by Administrator
iiTyran is offline
Old 05-24-2019, 01:40 AM
Administrator
Administrator
MR_LUV's Avatar
MR_LUV is offline
Old 05-25-2019, 06:25 PM
iiTyran's Avatar
Could you or someone else show me how to change my Fuel Injectors? I replaced the Oxygen Sensor, Cleaned the MAF Sensor, Changed the Spark Plugs, and changed the Fuel Pressure Regulator. So im thinking it has to be leaky Fuel Injectors
Thanks
iiTyran is offline
Old 05-26-2019, 12:39 AM
Administrator
Administrator
MR_LUV's Avatar
Check Out the Above Videos to get an Idea on Changing your Fuel Injectors.
Hope this helps.
MR LUV
__________________
MR_LUV is offline
Old 05-27-2019, 12:54 AM
Administrator
Administrator
MR_LUV's Avatar
Originally Posted by iiTyran
Could you or someone else show me how to change my Fuel Injectors? I replaced the Oxygen Sensor, Cleaned the MAF Sensor, Changed the Spark Plugs, and changed the Fuel Pressure Regulator. So I'm thinking it has to be leaky Fuel Injectors Thanks
Before you look at the Fuel Injectors, Look for cracked or rotted vacuum hoses causing leaks after the MAF.
As 2 SL Members recently found out on their P0172 problem:
CEL Code P0172: Help Needed
dogg: Post #38, #40
johnnymejia7: Post #39
MR_LUV is offline
pioneer411
58
12-17-2010 06:12 PM
Dkfung88
20
05-15-2010 07:54 PM
gompka
12
12-15-2008 07:38 PM
Djbombsquad
10
02-10-2006 07:01 PM
Raziemlutto1
07-08-2004 05:46 PM
Quick Reply: Code P0172..
