Cooling Oil and Tranny Fluid Idea. Thoughts?
Before I start...do the 5 speed guys have the taps for the auto tranny cooler on their radiator? Just curious because if you do, it might make a good oil cooler as well for turbo apps. I'm not sure.
I was thinking of adding a better tranny cooler and an oil cooler. But at the same time, there is a built in tranny cooler in the stock radiator. I'm wondering, if I install an external tranny cooler (they are alot cheaper than oil coolers) and run an engine oil line to the stock tranny cooler if it would help much for the engine oil. Even 30 degrees would be great. Pressure would be the major issue that I can think of. If I did this, would it be a good idea to tap the line going to the turbo and cool the oil before or after the turbo? Or, I have 2 remaining taps on the oil filter block taps for the oil gauges. Just route one tap out to the cooler and route back into the 2nd tap. I think it would be best to cool after the turbo and dump back in at the top sender position on the head. Any thoughts? |
Can you show me some pics of the taps ur talking about I can go check
and yea im thinking after cuz I dont think you wanna do before and then drop pressure on it and not know and then boom... But also u wanna make sure its flowing out just as much as dumping in or seals can go. |
Is the tranny cooler line -10 or larger? If it isn't it's a BAD idea to route post-turbo oil through it. You'd be way better off to use the taps on your filter block if the line is the size I think it is.
Turbos turn the oil into a chocolate mousse consistency. They are very hard on oil. Anyone racing a turbo car with the engine and turbo using the same oiling system will tell you to run 50wt for this reason. You really need the discharge line to be large and very freeflowing. If you don't you will have lots of turbo seal problems. |
show me some pics of the taps ur talking about.
ill have to look thanks
No, the manual has a different radiator. It would be really nice to have an oil/water cooler, but it isn't this easy for manual owners.
