Shifting into Reverse..
Does anyone have trouble from time to time Shifting into Reverse on a 5 speed?
____
____
On prior cars that I owned that had a similar problem, I also found that Shifting to 2nd, made going into reverse easier.
My friend told me it had to do with lining up synchros or somethin like that.
____
____
I found that if the car doesn't want to go into Reverse, just let the Clutch out in Neutral and try again. Works every time for me.
Also, you should be at a complete stop cause engaging reverse can be difficult even if you are rolling backwards.
__________________
__________________
What I do when it won't go into reverse is put it in first gear and go ahead just a little bit. Just so the wheels move a bit. Then stop, and it will slide right into reverse.
I know that some Toyota transmissions in the past have not had synchros on the reverse gear! This is why it is sometimes more difficult to get in R.
Therefore, if you go into any other gear first, like 3rd or 4th and then shift to reverse, it will engage much easier. Good luck!
_____
_____
Originally Posted by bbsciontc
I found that if the car doesn't want to go into reverse, just let the clutch out in neutral and try again. Works everytime for me. Also, you should be at a complete stop cause engaging reverse can be difficult even if you are rollling backwards.
It's not really a problem, just inherant of engaging a gear without a syncro. Most cars are like this. Reverse is not a critical gear, it just has to work, so they cut out syncros and use straight cut instead of helical gears which is why they whine when you go in reverse
when it wont let me go into reverse. I turn the car off, get out, yell a few obscenities directed towards her, then calmly apologize and get back in. Then it ussually works.
Only problem is, the whole way to my next destination, she knows im mumbling mean ____ to her the whole way.
engifineer: That was an amazing post. I'm not gonna lie but i totally expected a negative post. I
t's always good to see some people still have there sense of humor past the age of 21.
You my fav Premium Member! :D
__________________
__________________
