name a good 12lb flywheel
Old Mar 21, 2011 | 04:21 AM
JohnniiBoyyy's Avatar
Default name a good 12lb flywheel
buying an act clutch and want to also buy a 12lb lightweight flywheel but i dont know which one to choose from... any suggestions??
Old Mar 21, 2011 | 07:57 PM
jimmyjun's Avatar
i've been using the f1racing chromoly 12.5lbs on my n/a tc for over 3 years now, no problems what so ever.
Old Mar 21, 2011 | 08:00 PM
headlessmunky's Avatar
fidanza(sp?). I had the f1racing/ebay brand on my integra and it was decent, thats for a honda. lol. My tC will get the best
Old Mar 21, 2011 | 09:19 PM
would a 9.5lb fidanza flywheel be too much for a n/a 07 tc?
Old Mar 22, 2011 | 05:32 AM
XPRTc's Avatar
If you're looking into racing where you aren't starting at a dead stop, like auto crossing, then you'd benefit from a 9.5lb flywheel since it'll make it easier to keep RPMs elevated while you're navigating through the course; where if you're drag racing you're going to want to stick with a 12lb so you can launch better (you won't have to rev as high to get momentum in first). A 12lb would probably be a better choice if you DD your car and do stop and go city driving too.
Old Mar 22, 2011 | 03:07 PM
jimmyjun's Avatar
Exactly, plus you can resurface a chromoly or steel flywheel in the future if it is needed, Fidanza's cant be resurfaced... wich means more money to spend down the road.
Old Mar 22, 2011 | 07:34 PM
thx for that info, btw how are SPEC clutches, stage 2 in particular.. would it be better than a Competition Clutch stage 1?
Old Mar 22, 2011 | 07:45 PM
XPRTc's Avatar
Personally I went with an Exedy stage II cerametallic clutch. I recommend going Exedy because they manufacture a lot of OEM clutch applications in Japan, but do research on some prospective companies and the correct choice will surface. I highly suggest whatever you go with, to use the OEM throw out bearing cause it tends to be superior to aftermarket TOB failure.
Old Mar 22, 2011 | 08:17 PM
XPRTc's Avatar
I almost forgot that this thread is about Flywheels...
I'm using a 12lb Clutch Masters aluminum flywheel. I was seeking a 12lb steel flywheel but came across a sick deal plus the friction surface is steel and is replaceable. Not a bad route.
Bruno769
Feb 18, 2015 05:06 AM
BrokenTC2
Jan 27, 2015 03:32 AM
scsteven
Jan 25, 2015 01:06 AM
scionboxrox
Nov 24, 2014 06:38 PM
2fixA
Sep 29, 2003 08:36 AM
