Repairs during oil consumption warranty
I have a 07 Tc with 175k miles. I am getting the extended warranty oil consumption work done and the dealer wants to replace the timing chain, vvt gear, and tensioner for $780 and do a valve job and machine the heads for $850... anyone know if I should go ahead and do this? Is that a decent price? They said all parts no labor cuz its already apart? They also wanna replace the head bolts for $150 but I think head bolts are one time use anyway and I should ask if that should be included in warranty work? Any advice is greatly appreciated! Thanks!
@ 175K miles it is a tired motor. A little refresh would be a good idea.
So if those costs are just parts, see if you can buy the parts yourself, as they're priced high from the dealer. They will try to nickle and dime you to make some extra coin.
If they do head work tell them you want to see the head before and after to make sure they actually do the work. you'd be surprised how shady some dealers can be. Price out a head service at a local machinist and see if you can take the head there to save some cash.
Regarding the head studs/bolts, They may have broken a head bolt and are trying to stick you with the cost. Check this as well.
If you plan on keeping the car I would ave the work done. It will be like a brand new motor! and with the upgrades, it will easily last another 200K
Good luck man.
Good luck man.
Good luck man.
Good luck man.
I will tell you that there is a design defect with the factory head bolts. It's what leads to the head separating from the block. It usually happens when the water pump fails, and that heating up pulls the cylinder away from the block. I am NOT defending the dealer at all, check the bolts that are in there and I bet you'll see none of them are broken. It sounds like this dealer is trying to get you to fix some of the design flaws instead of doing the minimum. Are they trying to make extra $$$? Could be, but a lot of this sounds like they're trying to make it where you won't have to have future work done. With this new work you're looking at more than 2 more years.. try another 200-300k miles!
The defect isn't actually the head bolts themselves, but the internal threads in the block. When the engine overheats, the bolts are put in tension, and the threads in the block can get pulled out. The fix is actually drilling, tapping and inserting a helicoil into the block to replace the damaged threads. I haven't heard of an issue with the bolts themselves, but I could be wrong.
The work they are asking you for is not a bad idea considering the mileage, but clearly the dealer is trying to make some money on this as Toyota corporate gives them a crappy rate on the recall work. I would look at like this: If you're planning to keep the car until it dies, it's probably worth it. If you will be selling/trading the car in a year or two, I probably wouldn't bother.
