Replacing Rear Mount?
Anyone got a write-up on changing the Rear Mount?
I just want to know how much work is involved in changing this mount before I start and run into any issues.
_____
_____
Its quite simple. Put jack under the motor to hold it up/in place... Remove s-pipe and unplug 02 sensor, remove driver side tire, remove subframe (optional) I never did, and start by loosening the big bolt which you can access with a socket wrench and a long extension from the drivers side area where the tire was. Take that out and then loosen the others. After that make sure the jack is holding the motor up a little bit and wiggle that rear mount out anyway you can. Wasnt to hard for me to get out and I didnt remove subframe. Good luck bro..
KillaSpiceTSW
Apr 13, 2010 03:57 PM
