supercharger question
Old 02-21-2008, 09:16 PM
sc1onk1lla's Avatar
Default supercharger question
im bidding on a supercharger on ebay here is the link http://cgi.ebay.com/ebaymotors/ws/eB...TODAY.m238.lVI
now my question is, what else would i need to purchase if this only comes with the supercharger and the driveshaft.......
sc1onk1lla is offline
Old 02-21-2008, 09:21 PM
mitchelltc1's Avatar
Well, I'd look at the installation manual. There is a lot more, but the big thing I can think of is the TRD refash.
mitchelltc1 is offline
Old 02-21-2008, 09:27 PM
hawgs74's Avatar
U get the reflash at the dealer...no need to buy it
hawgs74 is offline
Old 02-21-2008, 09:33 PM
sc1onk1lla's Avatar
what im asking is what else i would need to purchase with what i would get from this ebay seller
Old 02-21-2008, 09:38 PM
You'd have to contact TRD or Vortech... There would be a lot of stuff... air lines, new air box, BPV, pulley, belt... See if you can at least find a "packaging list" on a new one or a parts list from the isntallation manual. I bet a lot of the stuff you can't even buy separate, but good luck!
Old 02-21-2008, 09:40 PM
tCtCtC's Avatar
everything except the supercharger and the shaft.
its the s/c only, no hoses or anything
tCtCtC is offline
Old 02-21-2008, 09:59 PM
ifastsctc's Avatar
1200 buy it now? you can get a new one for 1500 with everything. yuo need brackets, injectors, computer map $ 400 atleast. not to mention a lot of other parts. get a new one!
ifastsctc is offline
Old 02-21-2008, 10:07 PM
ninjaionsobe's Avatar
i hate to be the voice but walk away from this
the truth its not worth it. i am 6 feet under doing it this way and the kit i got had almost every thing
he saying somthing about a warranty. on it forget that no one in their right mind will cover this
pretap oil pan 125
the fuel injector ? but they must cost some green
the crank shaft new bolt 85.00
fule line 50
fule line plastic cap ?
who knows if the pulley come with it
or how bad of shape they are in
new bpv that will run 150 you going to want something better then the stock one
ill spitball some items and numbers out for you <don't want to wreck a dream>
TRD 2.4AZ S/C, Cold Plug Replacement Part PTR24-21050-00
TRD, Spark Plug PTR24-21055-01
TRD 2.4AZ S/C, Rear Bracket Replacement Part PTR25-21060
TRD 2AZ S/C, Drive Belt Replacement Part PTR30-21060
TRD 2.4AZ S/C, Wire Harness Relocation Kit Replacement Part PTR41-21050
TRD 2.4AZ S/C, Bracket Kit, AC Hose / Wire Harness Relocation Replacement Part PTR41-21051
TRD 2.4AZ S/C, Oil Feed Line T-Adaptor, AN to NPT Fitting, ByPass Valve Tee Replacement Part PTR41-21052
TRD 2.4AZ S/C, Idler Bracket Bolt w / Oil Return Line Hardware Kit Replacement Part PTR41-21053
TRD 2.4AZ S/C, Valve, Bypass Replacement Part PTR41-21054
TRD 2.4AZ S/C, Air Box Assy Kit Lower w/inlet Adaptor Replacement Part PTR41-21055
TRD 2.4AZ S/C, ECU Remap Module Replacement Part PTR41-21056
TRD 2.4AZ S/C, Crank Position Sensor Wire Ext. Assy. Replacement Part PTR41-21057
TRD 2.4AZ S/C, VSV Rubber Mount, VSV Hose & Bypass Valve Hose Kit Replacement Part PTR41-21058
TRD 2.4AZ S/C, Hose, Oil Feed Assy Replacement Part PTR41-21059
TRD 2.4AZ S/C, Rear Mounting Bracket, assembly, Aluminum Cast Replacement Part PTR41-21060
TRD 2.4AZ S/C, Crankshaft Bolt Replacement Part PTR41-21061
TRD 2.4AZ S/C, Idler Pulley Replacement Part PTR41-21062
TRD 2.4AZ S/C, Driven Pulley w/Hardware Kit Replacement Part PTR41-21063
TRD 2.4AZ S/C, Air Box Rubber Mounts & Sleeves Replacement Part PTR41-21064
TRD 2.4AZ S/C, Driven Pulley Shim Asst. Kit Replacement Part PTR41-21065
TRD 2.4AZ S/C, Clamp Kit Replacement Part PTR41-21066
TRD 2.4AZ S/C, Idler Pulley Hardware Kit Replacement Part PTR41-21067
TRD 2.4AZ S/C, Inlet Cover Replacement Part PTR41-21068
TRD 2.4AZ S/C, O-Ring, Supercharged tC Replacement Part PTR41-21069
TRD 2.4AZ S/C, Oil Pan w/ Return Tube Replacement Part PTR41-21160
TRD 2.4AZ S/C, Thermostat, 70C / 160F Replacement Part PTR41-21161
TRD 2.4AZ S/C, Formed Fuel Line Assembly Replacement Part PTR41-21162
TRD 2.4AZ S/C, Fuel Injectors, High-Flow Replacement Part PTR41-21163
TRD 2.4AZ S/C, Gasket, HC Trap Holder, Buna Replacement Part PTR41-21164
TRD 2.4AZ, Supercharger Main Assy. Replacement Part PTR41-21165 <good news this is the thing you bidding on> so you wont need it
TRD 2.4AZ S/C, Insulator, Exhaust: Stamped Replacement Part PTR41-21166 <you wont need this
TRD 2.4AZ S/C, Hose Kit: Inlet/Outlet/Bypass Replacement Part PTR41-21167
TRD 2.4AZ S/C, Hose, Water Return Replacement Part PTR41-21168
TRD 2.4AZ S/C, Oil Return Hard Line Assy. Replacement Part PTR41-21169
TRD 2.4AZ S/C, Rear Bracket & Inlet Cover Hardware Replacement Part PTR41-21170
ninjaionsobe is offline
Old 02-22-2008, 05:31 AM
kikcaffine's Avatar
Well if you must ask..... Its going to run you about a grand in extra parts. Its really not worth it, just get a used complete kit from someone. Hell the reflash is close to 700 dollars alone. This is great if you want an extra blower to mess with or change the wheel out with a t-trim.
kikcaffine is offline
Old 02-22-2008, 05:46 PM
enjoithis's Avatar
where are they new for 1500? 08?
enjoithis is offline
Old 02-22-2008, 07:12 PM
kikcaffine's Avatar
They arent for the 2008's.
Old 02-22-2008, 07:15 PM
enjoithis's Avatar
Old 02-22-2008, 07:41 PM
Nick06tC's Avatar
Do not buy it!!!
Nick06tC is offline
Old 02-22-2008, 07:45 PM
2_much_tc's Avatar
don't do it!!! get a new one...
2_much_tc is offline
bootlgr
01-26-2016 01:22 AM
Greg S
05-28-2015 12:46 AM
jairolla_89
04-02-2015 09:41 PM
Scionxa180
03-13-2015 04:39 AM
TotalChaos
13
02-04-2015 10:24 PM
Quick Reply: supercharger question
