TRD filters
Old Apr 23, 2007 | 08:25 PM
StrdtC's Avatar
Default TRD filters
So I did what EXACTLY what your not supposed to do when u first get ur cold air intake, and that was go through water. What did I care, I had the TRD with the bipassvalve and what not. Perhaps Im wrong now that i see my engine light is on...However, I was wondering if anyone knew or could find out dimentions for the filter on the trd CAI. The diameter of the hole the tube goes into, the length of the filter itself and any other important measurments needed to replace the filter. K&N might be able to custom make filters for TRD intakes I hear...I wanna see. THANK YOU!
"Why's the rum gone..?"
Old Apr 24, 2007 | 01:41 PM
krdshrk's Avatar
Moved to the appropriate section.
You can also try cleaning the filter - get a K&N Filter recharge kit.
Old Apr 24, 2007 | 01:46 PM
timmyinpajamas's Avatar
DeepSouth Scions
its like the most common filter size .. any tuner filter will fit .. get the aem dry flow
Old Apr 25, 2007 | 04:46 AM
hPower's Avatar
The AEM filter should work. Good luck.
Old Apr 25, 2007 | 02:32 PM
trdsparks's Avatar
The TRD filter has a 2 1/2 inch opening. Here's a link to the thread. Alot of ppl for together and put this together.
https://www.scionlife.com/forums/vie...=asc&&start=40
Just for the record bypass valve doen't mean hit every puddle you still should try to avoid them. The Bypass valve will prevent hydrolocking but there is a limit.
DJ_FroZone
25
May 30, 2019 07:17 PM
airmankevin1
Feb 14, 2018 01:23 PM
hampton1100
May 28, 2015 07:32 AM
carid
Mar 30, 2015 07:08 AM
JPuehl
Jan 10, 2015 01:01 AM
