6-speed tC1 swap kit
Old Feb 6, 2015 | 01:02 PM
  #401
SloTC1's Avatar
Originally Posted by Desp7397
How much would a E351 tranny and a LSD run I wonder.
150-400 for the trans and 600-1700 depending on which LSD you go for and roughly 700-1500 if you get a shop to install
Old Feb 6, 2015 | 01:44 PM
  #402
Desp7397's Avatar
That's not to bad I guess
Old Feb 15, 2015 | 06:45 AM
  #403
Travis589's Avatar
I'm still driving the original swap kit for the TC1 with an os giken lsd. I just clocked over 80k miles since descendant did the swap years ago. Everything works perfect except for there is a pop on the drivers side axle. It has made the noise since the swap and yes I have replaced the axles. Pretty sure it's binding but it only does it at low speeds while turning. Normal driving on the highway and no noise. Maybe when I get my tax return I'll rip out the driver axle and replace it with a TC2 axle otherwise I'll get a custom one. Other than that the 6 speed swap has been great.
Btw the 6 speed transmission holds at least 350 hp because there is one bolted directly to an 2grfe that is supercharged in a first generation toyota mr2 in the uk. Seen the build and the numbers so it's good for some power. I'm in the process of building the same setup but in a 2nd generation toyota mr2.
Also you can pick these transmissions up now for about $600-$700. I paid $1500 for mine new from descendent which was still cheaper than one from toyota.
Old Dec 6, 2015 | 09:38 AM
  #404
PseudoKirby's Avatar
So those of you whove done this swap... reusing tc1 axles?
evolving_machine
Oct 21, 2023 01:16 PM
ColonelSanders85
Dec 9, 2020 09:44 AM
ColonelSanders85
Mar 3, 2015 03:31 AM
