AEM FIC help
I have a 2011 xb with world racing turbo kit running the AEM FIC preloaded base map it's not install yet but trying to get some help and nobody from the xb2 side had a answer so looking here.
I have the plug in play ecu harnass but the plug that goes to the fic one of the wires came loose orange n black but idk where it goes
Second how do you sync the FIC to the car after installing it the install video says it has to be synced
Appreciate any help
Appreciate any help
You'll want the harness diagram. If you Google it, you should be able to find the plug and play harness pin sheet. Crush has one stickied I think? If you google search "scion tc aem fic setup" it should be the first link.
Once you plug that back in, you need to press the "connect" button in the FIC 6 software and assuming the wiring is good, you can select "from FIC" unless you have the tune you want already loaded in the FIC 6 software, then you would select "From PC".
1. Open FIC 6 on laptop
2. Open the calibration file
3. Plug PC into FIC
4. Find and press the button in the FIC 6 software that says "Connect", it should resemble a squiggly line connecting two small boxes.
5. Once the PC verifies connection, it will prompt you to select where to load the tune from. SELECT FROM FIC IF YOU DO NOT HAVE A COPY OF YOUR TUNE!!!
6. You are now connected to the FIC.
Not sure what sort of "sync" you need to do. Maybe update the firmware? I am still running old firmware and need to update it. When you take the car to your tuner, he may find this information helpful as far as the connection process goes. Also, I do believe this information has been provided in other, older, threads.
3. Plug PC into FIC
Got the Turbo installed and it won't start but when I use the jumper harness to bypass the fic it started right up. I have no idea what to do I ended up removing the turbo cause I need my car if anyone knows why the fic didn't work please let me know
3. Plug PC into FIC
3. Plug PC into FIC
Could this be the problem look at figure 3
I bought this aem fic used so do I have to do these steps to every vehicle it goes into?
If it was purchased used with a similar model or engine then you should be able to use the previous tune to limp to the tuner. If it was used on a completely different setup, then you will have to start from scratch I would presume but that's just a guess.
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
